ASUS GeForce® GTX 780 DirectCU II gives new edge to hardcore gamers
- DirectCU II achieves 30% lower temps with 220% the dissipation area, plus 3X quieter running than reference
- Exclusive CoolTech Fan drives wider airflow to keep critical components cool
- DIGI+ VRM with 10-phase Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
Set the Cool Benchmark
ASUS GeForce® GTX 780 DirectCU II graphics cards feature an ASUS-designed PCB and a completely new look for the DirectCU II cooler, as well as DIGI+ VRM digital power delivery and robust Super Alloy Power components. GeForce® GTX 780 DirectCU II cards use an NVIDIA® GK110-300 GPU with 2304 CUDA cores. They ship with 3GB GDDR5 video memory on a 384-bit interface. For avid PC gamers who demand ultra-high detail and readiness for resolutions beyond full HD 1080p, GeForce® GTX 780 DirectCU II cards deliver extreme cooling, stability, and endurance well above reference card standards.
- DirectCU II: 30% cooler and 3X* quieter. Exclusive DirectCU II thermal design includes a direct-GPU contact 10mm copper heatpipe and 220% larger dissipation area to boost heat removal efficiency. It performs 30% cooler and 3X quieter than reference.
- CoolTech Fan: proprietary CoolTech fan consists of a hybrid blade and bearing design, with inner radial blower and outer flower-type blades. These provide multi-directional airflow to accelerate heat removal and enable highly stable graphics performance.
- DIGI+ VRM with Super Alloy Power: 30% less power noise and 2.5X greater durability. Acclaimed DIGI+ VRM has been applied via a 10-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference.
- GPU Tweak: Real-time intuitive graphics tuning. Shows detailed specs and actual card status with GPU-Z, Monitoring widget provides real-time detailed multi-parameter info and automatically checks and updates drivers and BIOS versions.
- 3GB GDDR5 Memory: On-board memory for the best gaming experience & the best resolution
I/O Ports Highlight
- 1x Native Dual-link DVI-I
- 1x Native Dual-link DVI-D
- 1x Native HDMI
- 1x Native DisplayPort
- Graphics Engine: NVIDIA GeForce GTX 780
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 3GB
- Engine Clock: GPU Boost Clock : 902 MHz / GPU Base Clock : 863 MHz
- CUDA Core: 2304
- Memory Clock: 6008 MHz ( 1502 MHz GDDR5 )
- Memory Interface: 384-bit
- Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D), HDMI Output : Yes x 1 , Display Port : Yes x 1 (Regular DP)
- HDCP Support : Yes
- Power Consumption: up to 300Wadditional 6+8 pin PCIe power required
- Accessories: 1 x Power cable, 1 x SLI Bridge
- Software: ASUS GPU Tweak & Driver
- ASUS Features: DirectCU Series, Super Alloy Power
- Dimensions: 11.3 " x 5.8 " x 1.6 " Inch / 28.7 x 14.73 x4.06 Centimeter
DirectCU II - 30% cooler and 3X quieter
Exclusive DirectCU II thermal design includes a direct-GPU contact 10 mm copper heatpipe and 220% larger dissipation area to boost heat removal efficiency. It performs 30% cooler and 3X quieter than reference. -
CoolTech Fan
Proprietary CoolTech Fan consists of a hybrid blade and bearing design, with inner radial blower and outer flower-type blades. These provide multi-directional airflow to accelerate heat removal and enable highly stable graphics performance. -
DIGI+ VRM with Super Alloy Power - 30% less power noise and 2.5X greater durability
Acclaimed DIGI+ VRM has been applied via a 10-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference. -
GPU tweak - real-time intuitive graphics tuning
It shows detailed specs and actual card status with GPU-Z. Monitoring widget provides real-time detailed multi-parameter information. It can automatically check and update drivers and BIOS versions. -
3 GB GDDR5 memory
The on-board memory is for the best gaming experience and the best resolution.
- ASUS GTX780-DC2-3GD5 - graphics card - GF GTX 780 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 780
- Memory
- 3 GB GDDR5
- Core Clock
- 863 MHz
- Boost Clock
- 902 MHz
- CUDA Cores
- 2304
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 384-bit
- DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
- API Supported
- DirectX 11.1
- 4.06 cm x 28.7 cm x 14.73 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 863 MHz
- Boost Clock
- 902 MHz
- CUDA Cores
- 2304
- API Supported
- DirectX 11.1
- Nvidia PhysX-Ready, Nvidia 3D Vision technology, Super Alloy Power technology, ASUS DirectCU II Technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, ASUS DIGI+ VRM, NVIDIA GPU Boost 2.0, CoolTech Fan, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 384-bit
- Additional Requirements
- 6-pin + 8-pin power connectors
- 300 Watt
- Cables Included
- 1 x SLI bridge
- Software Included
- ASUS GPU Tweak
- 4.06 cm
- 28.7 cm
- 14.73 cm
