- Model name GTX750TI-PH-2GD5
- Positioning Performance
- Bus Standard PCI Express 3.0
- Thermal Solution Single Fan
- Dust-Proof Fan design additionally dissipates heat efficiently while expending lifespan by 25%.
- Super Alloy Power Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference
- GPU TWEAK provides real-time and intuitive tweaking.
Supercharged, super-cool
GTX 750 Ti is an astonishing ngraphics card from ASUS - that's astonishing 3D gaming and astonishing value! Equipped with the powerful GeForce GTX 750 Ti graphics-processing unit (GPU) and GTX 750 Ti treats you to smoother, faster and more detailed gaming experiences. Fitted dust-proof fan for 25% longer graphics card lifespan, and equipped the card with exclusive super alloy power components for superior stability. GTX 750 Ti also comes with easy-to-use tuning tool, GPU tweak. Use this to squeeze every last drop of performance out of the card and then stream your sound-up on-screen action over the Internet in real time! -
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Real-time intuitive graphics tuning
Shows detailed specs and actual card status with GPU-Z, monitoring widget provides real-time detailed multi-parameter info, automatically checks and updates drivers and BIOS versions. -
Stream online instantly
GPU tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GTX750TI-PH-2GD5 - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 640
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- 2 x DVI-D (dual link) , VGA , HDMI
- API Supported
- DirectX 11
- 3.9 cm x 18.2 cm x 11.5 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- CUDA Cores
- 640
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- Native HDMI, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, GPU Tweak Streaming, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3.9 cm
- 18.2 cm
- 11.5 cm
