Asus GeForce GTX 1060 3GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: CGN7WS00 Mfr#: DUAL-GTX1060-3G
ASUS Dual series of GeForce GTX 1060 comes equipped with wing-blade fans for max air flow with more air pressure. While Auto-Extreme technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
  • The sweet spot performance
  • Max air flow with more air pressure
    A wing-blade design delivers maximum air flow and improved static pressure over the heat sink, while operating at 3x quieter volumes than reference cards.
  • Premium quality and great reliability
    ASUS graphics cards are produced using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • Enjoy immersive virtual reality experience
    ASUS Dual series of GeForce GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
ASUS DUAL-GTX1060-3G - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
3 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1152
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5
4.3 cm x 24.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1152
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
Native HDMI, Dual Fan Design, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Wing-Blade Fans, NVIDIA Ansel, HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Additional Requirements
6 pin PCI Express power connector
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
4.3 cm
24.2 cm
13 cm
