Asus 710-1-SL
Auto-eXtreme technology for better Performance & Longevity!
ASUS exclusive Auto-eXtreme Technology is an industry-first, 100% automated production process that incorporates premium materials to set a new standard of graphics card quality, performance and longevity. Embedded with ASUS exclusive Super Alloy Power II, graphic cards can reach to 2.5 times product lifespan longer than traditional capacitors.
ASUS 710-1-SL comes with exclusive GPU Tweak utility, which allows users to modify clock speeds and voltages.
0 dB silent cooling
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. -
AUTO-EXTREME technology with Super Alloy Power II
ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
- ASUS 710-1-SL - graphics card - GF GT 710 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 710
- Memory
- 1 GB DDR3
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-D , VGA , HDMI
- API Supported
- OpenGL 4.4, DirectX 12
- Fanless
- 2.7 cm x 13.5 cm x 12 cm
- Graphics card - fanless
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- Max Resolution
- 2560 x 1600
- API Supported
- ASUS 0-dB thermal solution, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 64-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak II
- 2.7 cm
- 13.5 cm
- 12 cm
