Asus E3 PRO GAMING V5 Intel C232 S1151 DDR4 M.2 USB3.1 ATX
Quicklinx: BWZXWS00 Mfr#: E3 PRO GAMING V5
Be the winner on the battlefield with E3 Pro Gaming V5's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. SupremeFX's superior components maximize acoustic performance and eliminate interference - so you hear only the ultimate from your gaming headset or speakers! Banish analog interference and enjoy eye-catching, customizable lighting effects.
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill. Only the extremely quick shot survive, so E3 Pro Gaming V5 banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the exceptional networking technology, including tournament-level Gigabit Ethernet and LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall. Featuring the advanced Ethernet for faster, smoother gaming - anytime. The LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Flawless audio that makes you part of the game
  • SupremeFX - shielded audio, superior sound
  • Illuminated shielding
  • Premium audio capacitors
    Fine-quality components that produce a warmer, natural sound with exceptional clarity and fidelity.
  • Scan and detect to dominate
  • Top-speed protected networking
  • Gigabit Ethernet
  • Pumped-up throughput - optimum surge protection
  • Gamer's guardian for real-world protection
    Protect your back in the game and let E3 Pro Gaming V5 protect all sides in the real world. Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future.
  • Built for gaming
    E3 Pro Gaming V5 is built for play, shaped by professional gamers - strong enough storm through the industry's punishing labs workouts. With E3 Pro Gaming V5 you do more than just play - you'll experience gaming on the edge of reality.
  • Audio connector
    Capacitor protection on both front and back audio-output circuits.
  • LAN connector
    ESD TVS diode protection and an anti-surge LAN connector protects against extreme events, such as lightning strikes.
ASUS E3 PRO GAMING V5 - motherboard - ATX - LGA1151 Socket - C232
Motherboard - ATX
Chipset Type
Intel C232
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 v5 series
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C232
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
SupremeFX
LAN
Network Controller
Intel I219LM
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1 (auto turn-off if all PCI Express 3.0 x4 slots are occupied) , 2 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 1 x USB-C , 4 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, Sonic Radar II, USB 3.1 Boost, ASUS Gamer's Guardian
Cable ties, cable labels, 1 x M.2 screw, I/O back cover
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger+, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS RAMCache
Plug and Play
30.5 cm
24.4 cm
