EAH6670/DIS/1GD5: ASUS HD6670 graphics card with DirectX®11, HDMI, and Eyefinity support
- Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Dust-proof fan design dissipates heat efficiently and extends card lifespan by 25% longer
- Extends your visual horizon across three displays for engaging entertainment
EAH6670/DIS/1GD5 features Super Alloy Power technology, which uses special alloy formula in critical power delivery components for a 15% performance boost, 35 °C cooler operation and 2.5 times longer lifespan. AMD Eyefinity technology extends your visual horizon across three displays for engaging gameplay and entertainment.
Super Alloy Power
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35 °C cooler operation and 2.5 times longer lifespan. -
It extends your visual horizon across three displays for engaging gameplay and entertainment. -
Dust-proof fan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
ASUS Smart Doctor
Intelligent system monitoring is designed for efficient overclocking with an intuitive slide bar. -
ASUS Gamer OSD
Real-time overclocking, benchmarking and video capturing in any PC game! -
AMD HD3D technology
It optimizes stereoscopic 3D gaming and movie-watching entertainment. -
AMD CrossFireX technology
Gets up to 1.8x of a graphics performance boost in dual mode. -
Microsoft DirectX 11 support
Bring some levels of visual realism to gaming on the PC and get top-notch performance.
- ASUS EAH6670/DIS/1GD5 - graphics card - Radeon HD 6670 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- AMD Radeon HD 6670
- Memory
- 1 GB GDDR5
- Core Clock
- 810 MHz
- Effective Memory Clock
- 4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- DVI-I , HDMI , DisplayPort , VGA - with adapter
- API Supported
- DirectX 11
- 16.8 cm x 11.7 cm
- Package Type
- Retail
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- ASUS SmartDoctor, ASUS GamerOSD, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, Super Alloy Power technology, Dust-proof fan, HDCP
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4 GHz
- Bus Width
- 128-bit
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities
- 16.8 cm
- 11.7 cm
- Package Type
- Retail
- Limited warranty - 3 years
