The ARCTIC F8 integrates some delicate features to improve the overall airflow and noise control management. Moreover, the refined "ninja-knife" impeller design not only improves the laminar airflow, but it also lowers the noise level. Tested by hundreds of simulations, the result is significant – airflow is over 20% higher compared with a generic 7-blade case fan.
- ARCTIC F8 - case fan
- Product Type
- Case fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 28 cfm
- 70 g
- 6-year warranty
- Product Type
- Case fan
- 70 g
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 28 cfm
- Limited warranty: - 6 years
