This 1-metre charge cable is made with a woven design — with USB-C connectors on both ends — and is ideal for charging, syncing and transferring data between USB-C devices. It supports charging of up to 60 watts and transfers data at USB 2 rates. Pair the USB-C Charge Cable with a compatible USB-C power adapter to conveniently charge your devices from a power point and take advantage of fast-charging capabilities. USB-C power adapters sold separately.
- Apple - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Sync and charge, woven design
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 1-year warranty
- USB-C cable
- Length
- 1 m
- Connector
- 1-year warranty
