Apple USB-C to Magsafe 3 Cable (2 m)
Quicklinx: GK10WS00 Mfr#: MLYV3ZM/A
Device Type: iPad, iPad Air, iPad Pro
Type: Cable
Device Screen Size: [N/A]
Colour: White
23 In Stock
£39.39 ex VAT
£47.26 inc VAT
This 2-meter charge cable features a magnetic MagSafe 3 connector that helps guide the plug to the power port of your MacBook Pro. Pair it with a compatible USB-C power adapter to conveniently charge your MacBook Pro from a power point and take advantage of fast-charging capabilities. The magnetic connection is strong enough to resist most unintended disconnects, but if someone trips on the cable, it releases so your MacBook Pro stays put. An LED turns amber when the battery is charging and green when it's fully charged. Made with a woven design for long-lasting durability.
Apple - power cable - 24 pin USB-C to MagSafe 3 - 2 m
Power cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
Apple MagSafe 3 - male
1-year warranty
MacBook Air (Mid 2022, Mid 2023); MacBook Pro (Early 2023, Late 2021)
Power cable
Length
2 m
Connector
24 pin USB-C - male
1-year warranty
Apple MacBook Air (Mid 2022, Mid 2023) , Apple MacBook Pro (Early 2023, Late 2021)
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Pro
Type: Cable
Colour: White
Brand: Apple
