The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
- Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
- Keyboard and folio case
- Backlit
- Interface
- Apple Smart connector
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- White
- Designed For
- 10.9-inch iPad Air (4th generation, 5th generation); 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation)
- Backlit
- Interface
- QWERTY UK
- Region
- United Kingdom
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
Carrying Case
- Magnetic connection, adjustable viewing angles
- USB-C
- White
- Designed For
- Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation)
