The Magic Keyboard is an amazing companion for your device. It features a great typing experience. The Magic Keyboard has a floating cantilever design, allowing you to attach your device magnetically and to smoothly adjust it to the perfect viewing angle for you.
Convenient magnetic connection
The magnetic connection allows for easy integration with compatible devices, making setup and storage simple. -
Flexible viewing angles
Adjustable viewing angles enable users to find a comfortable position for typing or viewing content. -
Integrated trackpad
The built-in trackpad offers a fluid navigation experience, allowing users to interact with their devices effortlessly. -
Responsive backlit keys
Backlit keys enhance visibility in various lighting conditions, ensuring effective typing both day and night. -
Apple Smart connector compatibility
Utilizing the Apple Smart connector ensures reliable connectivity and power efficiency between devices.
- Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK Input Device
- Keyboard and folio case
- Backlit
- Interface
- Apple Smart connector
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- 1-year warranty
- Designed For
- Apple 10.9-inch iPad Air (4th gen, 5th gen), 11-inch iPad Air (M2), 11-inch iPad Pro (1st gen, 2nd gen, 3rd gen, 4th gen)
- Backlit
- Interface
- QWERTY UK
- Region
- United Kingdom
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
Carrying Case
- Magnetic connection, adjustable viewing angles
- USB-C
- Limited warranty - 1 year
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H3C7 049232 Condition: Damaged stock - Item is new but has no original packaging |
£169.43 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
