Apple Adaptor Mini DVI to VGA for G4
Quicklinx: 4JNPWS00 Mfr#: M9320G/A
The Apple Mini-DVI to VGA Adapter is designed for use with the iMac (Intel Core Duo), MacBook, and 12-inch PowerBook G4. Connect the adapter to the Mini-DVI port of the computer and the VGA end of the adapter to an external VGA monitor or projector. You can use this cable in both video mirroring and extended desktop modes.
Apple VGA adapter
VGA adapter
Connector
Mini-DVI - male
Connector (Second End)
HD-15 (VGA) - female
PowerBook G4
VGA adapter
Connector
Apple mini-DVI - male
15 pin HD D-Sub (HD-15) - female
Apple PowerBook G4
