Hot-swappable battery ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
Plug-and-Play external battery ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
Battery modules connected in parallel
Delivers higher availability through redundant batteries. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced. -
Plug-and-Play external batteries
Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS. -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Modular design
Increases adaptability with an open architecture configurable to any IT environment.
- APC Extended Run - power array cabinet
- Power array cabinet - rack-mountable
- Rack Size
- 13U
- 313 kg
- Input Voltage
- AC 230 V
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 9 (supported) 9
- Black
- 47.2 cm x 68.6 cm x 57.2 cm
- 2-year warranty
- Designed For
- P/N: AR3357X674, ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16RMICH, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16RMI, SYA16K16RMICH, SYA4K8RMI, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16RMI, SYA8K16RMICH, SYA8K8I, SYA8K8RMI, SYAF16KRMICH
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 13U
- Black
- Supported Battery Technology
- Lead Acid
- Input Voltage
- AC 230 V
- Quantity
- 9 (supported) 9
- Technology
- Lead Acid
- Voltage Provided
- 120 V
- CSA, VCCI, BSMI, EN 60950, UL 1778, VDE, IEC 60950, EN 50091-2, EN 50091-1
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 47.2 cm
- 68.6 cm
- 57.2 cm
- 313 kg
- Designed For
- P/N: AR3357X674, ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16P, SYA12K16PXR, SYA12K16RMI, SYA12K16RMICH, SYA12K16RMP, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16P, SYA16K16PXR, SYA16K16RMI, SYA16K16RMICH, SYA16K16RMP, SYA4K8I, SYA4K8P, SYA4K8RMI, SYA4K8RMP, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16P, SYA8K16PXR, SYA8K16RMI, SYA8K16RMICH, SYA8K16RMP, SYA8K8I, SYA8K8P, SYA8K8RMI, SYA8K8RMP, SYAF16KRMICH
APC Symmetra LX Battery Module | In Stock | £618.03 |
APC Service Pack 3 Year Warranty Extension | In Stock | £1,001.56 |
