APC Surge Module for CAT6 or CAT5/5e
Quicklinx: B76ZWS00 Mfr#: PNETR6
Type: Module
Power Rating: [N/A]
£33.62 ex VAT
£40.34 inc VAT
Protects an Ethernet data port from damaging transients. Supports Cat5, Cat5E and Cat6 cabling standards. Compatible with Power Over Ethernet (POE) and network speeds up to 10GbE (10GigE).
  • Data-line Protection
    Protection of data lines (Ethernet, Coaxial and Phone lines) ensures complete protection of your equipment from surges. It is very important to protect your equipment from “back door” electric surges traveling through data lines, as they can be as damaging to your equipment as surges traveling over power lines
  • Replaceable surge protection modules
    Allows you to use any combination of APC rack-mount surge protection modules and replace them quickly and conveniently if needed
APC ProtectNet Surge Module for CAT6 or CAT5/5e Network Line - surge protector
Surge protector - plug-in module
20 g
1.9 cm x 6.9 cm x 4.4 cm
Surge Suppression
1 x Gigabit LAN - RJ-45
UL, UL 497B, RoHS
Limited warranty - lifetime
-15 °C
45 °C
0 - 95%
1.9 cm
6.9 cm
4.4 cm
20 g
Shipping Width
3.3 cm
Shipping Depth
9.5 cm
Shipping Height
9.9 cm
Shipping Weight
40 g
Type: Module
Power Rating: [N/A]
Brand: APC
