APC SMART-UPS SC 1000VA 230V
Quicklinx: 9123WS00 Mfr#: SMC1000I
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and network power protection. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
APC Smart-UPS C 1000VA LCD - UPS - 600 Watt - 1000 VA
UPS - external
17.27 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
600 Watt / 1000 VA
Input Connectors
Power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
USB
17.1 cm x 43.9 cm x 21.5 cm
P/N: AR3103, AR3103SP, AR3106SP, AR3357X674
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
600 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
455 Joules
Lead Acid
Recharge Time
3 hour(s)
Remote Management Interface
USB
USB cable - external
Audible alarm
GOST, UL 1449, VDE, RoHS, REACH
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
41 dBA
17.1 cm
43.9 cm
21.5 cm
17.27 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
19.55 kg
