APC Smart-UPS RT 3000VA RM 230V
Quicklinx: 5BHKWS00 Mfr#: SURTD3000RMXLI
Customize UPS capabilities with management cards. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable run time allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced.
  • SmartSlot
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS power overload or fault.
  • Scalable run time
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Hot-swappable batteries
    Ensure clean, uninterrupted power to protected equipment while batteries are being replaced.
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
  • Network manageable
    Provides remote power management of the UPS over the network.
  • LED status indicators
    Quickly understand unit and power status with visual indicators.
  • Serial connectivity
    Provides management of the UPS via a serial port.
  • Plug-and-Play external batteries
    Ensure clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Rack / tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Predictive failure notification
    Provides early-warning fault analysis ensuring proactive component replacement.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Audible alarms
    Actively let you know if the unit is on battery, if the battery is low or if there is an overload condition.
  • Power conditioning
    Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Resettable circuit breakers
    Enable a quick recovery from overload events.
APC Smart-UPS RT 3000VA RM - UPS - 2.1 kW - 3000 VA
UPS - rack-mountable
Rack Size
3U
54.6 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
2.1 kW / 3000 VA
Input Connectors
3 x power IEC 60320 C20, power BS 1363, power CEE 7/7
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
14.1 min at full load
RS-232
43.2 cm x 66 cm x 13 cm
Battery Enclosure Type
Plug-in module
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
2.1 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
2.5 hours
Remote Management Interface
RS-232
1 x management (RS-232)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable 2.4 m , Serial cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, internal bypass, LED indicators
CSA, VCCI, C-Tick, BSMI, GOST, EN 60950, EN 61000-3-2, JEON, UL 1778, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
55 dBA
43.2 cm
66 cm
13 cm
54.6 kg
Shipping Width
60.3 cm
Shipping Depth
98 cm
Shipping Height
34.7 cm
Shipping Weight
63.6 kg
5BHK APC NETSHELTER SX 24U In Stock £1,151.52
Resources
The following resources are available for the APC Smart-UPS RT 3000VA RM 230V
