APC Rack PDU, Switched, Zero U, 16A, 230V, (21)C13&(3)C19
Quicklinx: 3H93WS00 Mfr#: AP7951
APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets.
Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads (available on select models). Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
  • Network management
    Full-featured network management interfaces that provide standards-based management via Web, SNMP and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
  • Remote individual outlet control
    Remotely manage outlets so users can turn outlets off that are not in use or recycle power to locked-up equipment.
  • Power delays
    Allows users to configure the sequence in which power is turned on or off for each outlet. This helps avoid in-rushes at start-up, which can cause overloaded circuits and dropped loads. Sequencing also allows users to predetermine which piece of equipment is turned on first so other equipment dependant on that unit will function properly.
  • Load indicator LED
    This indicates overload and warning conditions based on the user-defined alarm thresholds, and alerts users of potential overloaded circuits.
  • Integrates with InfraStruXure Central
    An IT-ready, scalable monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
APC Switched Rack PDU - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.05 m
6 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309
Output connectors
21 x power IEC 60320 C13 , 3 x power IEC 60320 C19
6 cm x 4 cm x 162 cm
P/N: SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1UC, SCL500RMI1UNC, SMT1000R2I-AR, SMT1500R2I-AR, SMT2200R2I-AR, SMT3000R2I-AR, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1500RMNCUS, SMX1500RMUS, SMX2KR2UNCX145, SMX3000RMLVUS, SMX3KRMLVNCUS, SRT10RMXLIX806, SRT5KRMXLW-TW
Cord Length
3.05 m
Input Voltage
AC 230 V
Input Voltage Range
AC 200 - 250 V
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60309
Output Voltage
AC 230 V
Max Electric Current
16 A
Power cable 3.05 m
Rack Mounting Kit
Included
C-Tick, EN 60950, IEC 61000-3-2, IEC 61000-3-3, VDE, EN55024, EN55022 Class A
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
0 - 95%
Humidity Range Storage
0 - 95%
6 cm
4 cm
162 cm
6 kg
P/N: SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1UC, SCL500RMI1UNC, SMC1000-2UC, SMC1000-2UTW, SMC1000I-2U, SMC1000I-2UC, SMC1500-2UC, SMC1500-2UTW, SMC2000I-2U, SMC2000I2U-BR, SMC3000RMI2U, SMT1000R2I-AR, SMT1000RM2UC, SMT1000RMI2UC, SMT1500R2I-6W, SMT1500R2I-AR, SMT1500R2-NMC, SMT1500R2X122, SMT1500R2X180, SMT1500RM1U, SMT1500RM2U, SMT1500RM2UC, SMT1500RM2UNC, SMT1500RM2UTW, SMT1500RMI1U, SMT1500RMI2UC, SMT1500RMI2UNC, SMT1500RMUS, SMT2200I2U-BR, SMT2200R2I-AR, SMT2200R2X106, SMT2200RM2UC, SMT2200RM2UNC, SMT2200RM2UTW, SMT2200RMI2UC, SMT2200RMI2UNC, SMT2200RMUS, SMT30002U-BR, SMT3000R2I-6W, SMT3000R2I-AR, SMT3000R2X145, SMT3000R2X180, SMT3000RM2UC, SMT3000RM2UNC, SMT3000RM2UTW, SMT3000RMI2UC, SMT3000RMI2UNC, SMT3000RMJ2U, SMT3000RMUS, SMT750R2X122, SMT750RM2UC, SMT750RM2UNC, SMT750RMI2UC, SMT750RMI2UNC, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000US, SMX1500RMNCUS, SMX1500RMUS, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200HV, SMX2200HVNC, SMX2200RMHV2U, SMX2200RMLVUS, SMX2KR2UNCX145, SMX2KRMLVNCUS, SMX3000HV, SMX3000HVNC, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LVNC, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMJ2U, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750INC, SMX750NC, SMX750-NMC, SMX750US, SRC2000XLI-CC, SRC3000XLI-CC, SRT10KRMXLI, SRT10KRMXLT, SRT10KRMXLT-10KTF, SRT10KRMXLT30, SRT10KRMXLT-5KTF2, SRT10KRMXLT-IEC, SRT10RMXLIX806, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200RMXLI, SRT2200RMXLI-NC, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLI, SRT3000RMXLI-NC, SRT3000RMXLT, SRT3000RMXLT-5KTF, SRT3000RMXLT-NC, SRT3000RMXLW-IEC, SRT5KRMXLI, SRT5KRMXLI-6W, SRT5KRMXLIM, SRT5KRMXLT, SRT5KRMXLT-5KTF, SRT5KRMXLT-IEC, SRT5KRMXLTUS, SRT5KRMXLW-HW, SRT5KRMXLW-TW, SRT6KRMXLI, SRT6KRMXLI-6W, SRT6KRMXLIM, SRT6KRMXLT, SRT6KRMXLT-5KTF, SRT6KRMXLT-IEC, SRT8KRMXLI, SRT8KRMXLT, SRT8KRMXLT30, SRT8KRMXLT-5KTF, SRT8KRMXLT-IEC, SUA1000RM2UTW, SUA2200RM2UTW, SURT1000RMXLI-NC, SYAF16KRMICH
Resources
The following resources are available for the APC Rack PDU, Switched, Zero U, 16A, 230V, (21)C13&(3)C19
