The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection and easy-to-install safe system shutdown software all make this power protection solution the best value for home and home office computers.
- APC Back-UPS ES 700 - UPS - 405 Watt - 700 VA
- UPS - external
- 6.9 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ( 47 - 63 Hz )
- Power Capacity
- 405 Watt / 700 VA
- Output Connector(s)
- 4 x power BS 1363 ( surge ) , 4 x power BS 1363 ( UPS and surge )
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 3.5 min at full load
- 22.4 cm x 31.1 cm x 8.9 cm
- 3 years warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- Localisation
- United Kingdom
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connector(s)
- 1 x power BS 1363
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- 405 Watt / 700 VA
- Dataline Surge Protection
- Network/phone line - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 16 hours
- Cables Included
- 1 x power cable - integrated - 1.8 m , 1 x phone cable - external
- Audible alarm, LED indicators
- UL 1449, RoHS
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95%
- 22.4 cm
- 31.1 cm
- 8.9 cm
- 6.9 kg
- Shipping Width
- 27.9 cm
- Shipping Depth
- 40 cm
- Shipping Height
- 12.7 cm
- Shipping Weight
- 7.8 kg
