APC NetShelter CX 18U 750x1115
Quicklinx: 67D0WS00 Mfr#: AR4018I
NetShelter CX is a specialized enclosure with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
  • Lockable front doors
    Protect IT equipment from unwanted access
  • Light oak veneer finish
    The enclosure blends discretely into almost any office environment.
  • Acoustic foam lining for noise dampening
    Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment.
  • Six vertical 0U accessory channels
    Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space.
  • Removable side panels
    Provides customers with easy accessibility to equipment.
  • Dedicated rear cable access point
    Easy cable access near the rear of the IT equipment.
  • Integrated power distribution
    Provided with a rack power distribution unit servers and other equipment are ready for deployment.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment.
  • Adjustable leveling feet
    Leveling feet can be quickly adjusted through the use of a screwdriver or drill, eliminating the need to reach underneath with a wrench. Enclosures are shipped standard with both leveling feet and castors.
APC NetShelter CX - rack - 18U
Rack
Built-in Devices
Power distribution unit
Grey, oak
Rack Size
19"
Height (Rack Units)
18U
75 cm x 112 cm x 102 cm
138 kg
Wheels, key lock
Rack
Built-in Devices
Rack Size
19"
Height (Rack Units)
18U
75 cm
112 cm
102 cm
138 kg
Grey, oak
Weight Limit
455 kg
Wheels, key lock
EN 60950, RoHS, UL 60950-1
Limited warranty: - 2 years
