APC Home/Office SurgeArrest 6 Outs
Quicklinx: 4XDBWS00 Mfr#: PH6VT3-UK
APC's SurgeArrest was designed in response to customer requests for additional safety and convenience features. APC introduced plug-activated safety shutter and cord management to deliver increased security and ease of use, while superior power line and data line surge protection prevents damaging surge and spikes from ever reaching your equipment.
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Manual disconnect switch
    Enables the surge supressor to be de-energized for service without disconnecting the protected load
  • Right Angle Plug
    Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too
APC SurgeArrest Home/Office - surge protector
Surge protector - external
1.1 kg
United Kingdom
Input Connectors
1 x power BS 1363
Output connectors
6 x power BS 1363
Charcoal
12.2 cm x 4.2 cm x 30.5 cm
Charcoal
United Kingdom
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
6 x power BS 1363
Max Electric Current
13 A
Dataline Surge Protection
Phone line - RJ-11 - 1 input line / 2 output lines , Cable TV - RCA
Surge Suppression
Surge Energy Rating
2030 Joules
EMI/RFI Noise Filtration
50 dB
Circuit Protection
Circuit breaker
Power cable - integrated - 2.4 m , 2 x phone cable - external - 1.8 m , Coaxial RF cable - external - 1.8 m
GOST, UL 1449
Limited warranty - lifetime
0 - 95%
12.2 cm
4.2 cm
30.5 cm
1.1 kg
Resources
The following resources are available for the APC Home/Office SurgeArrest 6 Outs
