High-efficiency 3-phase UPS that features advanced product features, competitive specifications, and robust electrical design, making business continuity easy in the data center or electrical room. This is an exceptionally easy to install, operate, maintain, and service 30 kVA UPS, ideal for small and medium businesses. Includes dust filter and conformance-coated boards for harsh environments. This UPS is for internal batteries, but is supplied without batteries, so you can easily customize the battery runtime. For battery runtime details, see the runtime charts published under the Documents tab.
- Schneider Electric Easy UPS 3S E3SUPS30K3IB - UPS - 30 kW - 30000 VA
- UPS - external
- 584 kg
- Input Wiring
- 3-phase
- Input Voltage
- AC 400 V
- Output Voltage
- AC 400 V ± 3%
- Power Capacity
- 30 kW / 30000 VA
- Battery
- No battery
- Included Accessories
- Dust filter
- White
- 50 cm x 96.9 cm x 140 cm
- 1-year warranty
- UPS - external
- White
- Input Voltage
- AC 400 V
- Input Voltage Range
- AC 304 - 477 V
- Frequency Provided
- 50/60 Hz
- Input Wiring
- 3-phase
- Frequency Required
- 45 - 65 Hz
- Output Voltage
- AC 400 V ± 3% - 50/60 Hz
- Power Capacity
- 30 kW / 30000 VA
- Power Factor (PF)
- 0.99
- No battery
- Dust filter
- LCD display, LED indicators
- IEC 62040-3, IEC 62040-1-1, IEC 62040-2, WEEE, IP20, EAC, RCM, ISTA 2B, IEC 62040-4
- Limited warranty - 1 year - on-site
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 60 dBA
- 50 cm
- 96.9 cm
- 140 cm
- 584 kg
- Shipping Width
- 68.3 cm
- Shipping Depth
- 111.4 cm
- Shipping Height
- 164 cm
- Shipping Weight
- 638 kg
