Solid Shielding Partition facilitates overhead cable management, and offers protective grounding provisions and tool-less mounting.
Protective grounding provisions
Safety protection against electric shock and reduction of EMI emissions. NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment. -
Facilitates overhead cable management
Overhead cable troughs and partitions install toollessly on the roof of the enclosure eliminating the need for ceiling mounted or underfloor mounted cable trays. Cable troughs and partitions are designed to manage both power and data cables while maintaining separation.
- APC - cable shielding partition
- Product Type
- Cable shielding partition
- Black
- 73.2 cm x 7.2 cm x 12.2 cm
- 2.3 kg
- Designed For
- NetShelter; NetShelter SX
- Product Type
- 73.2 cm
- 7.2 cm
- 12.2 cm
- 2.3 kg
- Black
- Designed For
- APC NetShelter , APC NetShelter SX
