The APC SurgeArrest Audio-Video offers reliable surge protection for audio and video equipment.
Protection Working Indicator
SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge -
IEEE let-through ratings and regulatory agency compliance
APC surge protectors undergo stringent testing by IEEE, and are awarded "let-through ratings", which indicate the maximum voltage level that can possibly reach your equipment after a surge or voltage spike has passed through an electric surge protector. Lower IEEE let-through ratings indicate better protection and performance. The APC Essential SurgeArrest series offers optimal performance with a let-through rating of less than 330V to 500V for North American products, and a rating of less than 15% for products sold worldwide. All APC products comply with local agency safety requirements, including UL in North America and CE/Kema/Gost/C-tick/A-Tick/Telepermit in their respective regions -
Right Angle Plug
Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too -
Overload Indicator
Indicator illuminates when connected equipment draws more power than unit’s capacity. To remedy the condition, unplug less vital equipment
- APC SurgeArrest Audio-Video - surge protector
- Surge protector - external
- 1.2 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Connectors
- 1 x power BS 1363
- Output connectors
- 8 x power BS 1363
- Silver
- 12.2 cm x 4.2 cm x 37.2 cm
- Limited lifetime warranty
- Silver
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power BS 1363
- Power Output Connectors Details
- 8 x power BS 1363
- Max Electric Current
- 13 A
- Dataline Surge Protection
- Phone line - RJ-11 , Cable TV
- Surge Suppression
- Surge Energy Rating
- 2525 Joules
- EMI/RFI Noise Filtration
- 70 dB
- Cables Included
- Power cable - integrated - 3 m , 2 x phone cable - external - 1.8 m , Coaxial RF cable - external - 60 cm
- Equipment Protection Value
- 25000 British Pounds
- WEEE
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 12.2 cm
- 4.2 cm
- 37.2 cm
- 1.2 kg
- Shipping Width
- 21.6 cm
- Shipping Depth
- 5.1 cm
- Shipping Height
- 38.1 cm
- Shipping Weight
- 1.3 kg
