The APC Smart-UPS XL battery pack extension cable features Quick Plug-in Connections and is designed for SUA48 series battery packs.
Efficient power management
The APC battery cable is designed for seamless integration with PC systems, ensuring efficient power management and reliable performance. -
Durable construction
Crafted with durability in mind, this power cable is built to withstand the rigors of daily use, providing a dependable connection for your power needs.
- APC - battery cable
- Battery cable
- Black
- Designed For
- P/N: SUA2200R3XLNETPKG, SUA2200RMXLI3U, SUA2200UXICH, SUA2200XL, SUA2200XLI, SUA2200XL-NETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U-BR, SUA3000RMXLA3U, SUA3000RMXLI3U, SUA3000RMXLJ3U, SUA3000UXICH, SUA3000XL, SUA3000XLI, SUA3000XL-NETPKG, SUA3000XLT, SUA48RMXLBP, SUA48RMXLBP3U-TU, SUA48XLBP, UXABP48
- Battery cable
- Black
- Designed For
- P/N: SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA2200UXICH, SUA2200XL, SUA2200XLI, SUA2200XL-NETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA3000RMXLA3U, SUA3000RMXLI3U, SUA3000RMXLJ3U, SUA3000UXICH, SUA3000XL, SUA3000XLI, SUA3000XL-NETPKG, SUA3000XLT, SUA48RMXLBP, SUA48RMXLBP3U, SUA48RMXLBP3U-TU, SUA48XLBP, UXABP48
