Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Smart-UPS are trusted by millions of IT professionals throughout the world to protect equipment and critical data from costly interruptions by supplying reliable, network-grade power reliably and efficiently.
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics -
Cold-start capable
Provides temporary battery power when the utility power is out -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat -
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
- APC Smart-UPS SMC1000IC - UPS - 600 Watt - 1000 VA
- UPS - external
- 17.25 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 230 V
- Power Capacity
- 600 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 5 min at full load
- Networking
- USB
- Black
- 21.9 cm x 17.1 cm x 43.9 cm
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 180 - 286 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 47 - 63 Hz
- Frequency Required
- 50/60 Hz ± 3%
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Energy Rating
- 693 Joules
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 5 min at full load , 14 min at half load
- Remote Management Interface
- USB
- 1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
- Audible alarm, LCD display
- C-Tick, GOST, VDE
- Software Included
- APC PowerChute Business Edition
- 21.9 cm
- 17.1 cm
- 43.9 cm
- 17.25 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.74 |
APC 1U Vertical Cable Organiser | In Stock | £121.86 |
APC 1U Horizontal Cable Organiser | In Stock | £54.38 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £292.54 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £314.25 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £281.45 |
APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; | In Stock | £312.88 |
APC Cable Managers (Qty 10) | In Stock | £35.36 |
APC 2G Power distribution strip | In Stock | £627.52 |
APC 2U Horizontal Cable Organizer | In Stock | £57.69 |
APC Rack PDU 2G METERED ZEROU | In Stock | £683.94 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.45 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £924.71 |
APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch | In Stock | £1,926.60 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £78.78 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,442.54 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £65.06 |
APC Blanking Panel Kit | In Stock | £107.35 |
APC 1U Blanking Panel Kit | In Stock | £33.63 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.14 |
APC Basic Rack PDU Zero U - Power Distribution Panel | In Stock | £351.61 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,661.01 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £618.51 |
APC Replacement Battery Cartridge #142 | In Stock | £116.21 |
APC Metered Rack PDU | In Stock | £828.20 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £730.21 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £259.61 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,073.90 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £56.83 |
APC Service Pack 3 Year Warranty Extension | In Stock | £114.10 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £645.61 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.34 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £156.86 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £79.55 |
