Mini-ITX is the next "big" thing. And now, Antec introduces the ISK 300-150, designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a stable 150-watt power supply, the ISK 300-150 can handle many of the tasks of a traditional PC, but in half the space. From petite desktop options to silent home theater, Antec's ISK 300-150 is an epic case of mini proportions.
Compact design
The Antec ISK300-150 stands out with its small form factor, making it an ideal choice for users looking to save space without compromising on functionality. Its sleek design allows for easy integration into any workspace, providing a clutter-free environment. -
Efficient power
Equipped with a 150-watt power adapter, this chassis ensures efficient power usage while supporting all the necessary components for a mini ITX system. It's designed to keep your system running smoothly, even under load. -
Versatile expansion
Offering a front accessible bay and two internal bays for storage, alongside an expansion slot, the ISK300-150 provides ample room for system upgrades and expansions. This flexibility allows users to customize their setup as needed, ensuring longevity and adaptability of their computing environment.
- Antec ISK300-150 - SFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- Black
- Localisation
- United Kingdom
- I/O Connectors
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
- Installed Fans Qty
- 1
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- Manual fan speed control
- Power Device
- Power adapter 150 Watt
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 22.2 cm x 32.8 cm x 9.6 cm
- 2.5 kg
- 3-year warranty
- Form Factor
- Small form factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 2
- Front Accessible Bays Qty
- 1
- Black
- Fans
- Side: 1 x 8 cm - (1 installed)
- Localisation
- United Kingdom
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 1 x Expansion Slot
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- Power adapter
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 150 Watt
- 22.2 cm
- 32.8 cm
- 9.6 cm
- 2.5 kg
- Limited warranty - 3 years
