Take your projects further, faster with the AMD FirePro W8100 workstation graphics card which adds up to 4.2 TFLOPS of compute power to your graphics-centric workflows and comes equipped with ultrafast GDDR5 onboard memory.
4.2 TFLOPS of peak single-precision floating-point performance
Helps speed up time required to complete single-precision operations used within Video Effects and Rendering, Signal Processing, Transcoding and Digital Rendering applications where high performance takes precedence over accuracy. -
2.1 TFLOPS of peak double-precision floating-point performance
Helps speed up time required to complete double-precision operations used within Computational Fluid Dynamics (CFD), Structural Mechanics, Reservoir Simulation and Aerodynamics applications, where numerical precision is mission critical. -
Multi-GPU support
Combine up to four graphics cards in a single desktop system and leverage the combined processing power for personal supercomputing or to work with multiple 4K video streams in real time, layer in effects, make color corrections and edits on the fly. -
OpenCL 2.0 support
Enables professionals to tap into the parallel computing power of modern GPUs and multi-core CPUs to accelerate compute-intensive tasks in leading CAD/CAM/CAE and Media and Entertainment applications that support OpenCL. The AMD FirePro W8100 graphics card is expected to support OpenCL 2.02, allowing developers to take advantage of the features that give GPUs more freedom to do the work they are designed to do. -
Error Correcting Code (ECC) memory
Helps ensure the accuracy of your computations by correcting any single or double bit error as a result of naturally occurring background radiation. ECC support enabled on the external GDDR5 memory only. -
Partially Resident Textures (PRT)
PRT can utilize absolutely enormous texture files, with minimal performance impact. PRT accomplishes this by streaming small bits of these massive textures into the GPU as needed, giving compatible applications a virtually endless supply of unique texture data. -
AMD Eyefinity technology support
Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays powered by a single AMD FirePro W8100 graphics card. -
Future-ready for 4K
With four discrete DisplayPort 1.2 outputs and six display engines, the AMD FirePro W8100 graphics card can drive three 4K displays at 60 Hz and connects directly to four 4K displays. -
DirectGMA and SDI support
Removes CPU bandwidth and latency bottlenecks, and optimizes communication between GPUs within a system and third party devices like SDI I/O cards. DirectGMA bypasses any need to traverse the host's main memory, reducing CPU utilization and avoiding redundant transfers over PCIe, resulting in high-throughput, low-latency data transfers. -
Video Codec Engine (VCE)
Multistream hardware H.264 HD encoder for power-efficient and quick video encoding. -
Framelock/Genlock
Ensures accurate and consistent video synchronization to external sources or multiple GPUs in different systems. -
Energy-efficient design
AMD FirePro W8100 graphics card supports unique power monitoring and management technologies, and has a maximum power consumption of 200 Watts. AMD PowerTune technology dynamically optimizes GPU power usage and AMD ZeroCore Power technology significantly reduces power consumption at idle.
- Sapphire AMD FirePro W8100 - graphics card - FirePro W8100 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD FirePro W8100
- Memory
- 8 GB GDDR5
- Stream Processors
- 2560
- Memory Interface
- 512-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI (Single-Link): 1920 x 1200 / DVI (Dual-Link): 2560 x 1600 / DisplayPort: 4096 x 2160
- 4 x DisplayPort , 2 x DVI - with adapter , 3D glasses
- API Supported
- DirectX 11.2, OpenGL 4.4, OpenCL 2.0
- Package Type
- Retail
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- AMD FirePro W8100
- Stream Processors
- 2560
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- API Supported
- Dual Slot Fan Cooler, Error Correcting Codes (ECC) Memory, AMD PowerTune technology, AMD Stream technology, AMD GeometryBoost Technology, AMD AutoDetect Technology, Shader Model 5.0, AMD Eyefinity Technology 2.0, Digital Multi-Point Audio (DDMA), Graphics Core Next (GCN), AMD ZeroCore Power technology, Partially Resident Textures (PRT), Video Codec Engine (VCE), D.O.P.P., HydraVision, DirectGMA support, Genlock, Full 30-bit Display Pipeline, Unified Driver Architecture (UDA), Intra-System Framelock Support, Projector Overlap Support, Bezel Compensation, FreeSync Technology
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 512-bit
- Bandwidth
- 320 GBps
- OS Required
- Linux (64-bit), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Linux (32-bit), Windows 8.1 (32/64 bits)
- Min RAM Size
- 2 GB
- Required Power Supply
- 750 W
- Additional Requirements
- 2 x 6 pin PCI Express power connector
- 220 Watt
- Included Accessories
- Extender bracket
- Cables Included
- 2 x DisplayPort-DVI cable
- Software Included
- Driver
- UL, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE
- Package Type
- Retail
- Limited warranty - 3 years
