AMD Sapphire Firepro W4100 2GB GDDR5 Quad Mini DP PCI-E
Quicklinx: 9YCYWS00 Mfr#: 31004-51-40A
In a class of its own, AMD FirePro W4100 graphics, including four-display support, is the ideal choice for users who need a performance boost to address their evolving workflows.
  • 28 nm GCN (Graphic Core Next) Architecture
    The new 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in processing power and graphics performance.
  • AMD Eyefinity 2.0 multi-monitor technology
    AMD Eyefinity multi-monitor control technology features support for stereo 3D, universal bezel compensation and brand display configurations. AMD Eyefinity 2.0 enables easy multi-display setup and customization, virtually unlimited number of display devices, stereo 3D-multi-display stereoscopic 3D support via DisplayPort.
  • Full 30-bit display pipeline
    With a full 30-bit display pipeline producing more than one billion colors, the AMD FirePro is ideally suited for applications that benefit from accurate color reproduction and superior visual quality.
  • PowerTune
    This state of the art power management technology provides direct control over GPU power usage. Applications enjoy ultimate performance with dynamic clock optimization, while minimizing workstation energy usage.
  • AMD Zerocore Power technology
    AMD ZeroCore Power technology is the AMD exclusive technology that provides idle power reduction by shutting down GPU.
  • Quad HD display support
    4K support for ultra-high-resolution display devices and advanced configurations through DisplayPort and AMD Catalyst Pro drivers ensures future-forward compatibility for advanced workflows.
  • Projector overlap support
    Easily refine display alignment settings when configuring multiple, high resolution display devices or projectors.
  • Discrete Digital Multi-Point Audio (DDMA)
    DisplayPort 1.2 simultanesously outputs multiple, independent audio streams.
  • Bezel compensation
    Stretch display resolutions to prevent bezel interference and image distortion when displaying a single large image across multiple displays.
  • Video Codec Engine (VCE)
    Powerful, "fixed-function" multi-stream hardware dramatically improves the performance of HD encoding for a range of applications and pipelines.
  • HydraVision
    Use HydraVision to manage desktop displays and workspaces in multi-display environments: explicitly set the behavior of pop-up windows and dialogs in different applications though Desktop Manager, provide multiple layers of the desktop workspace through Multi Desktop, restrict application window placement across multiple desktops through HydraGrid.
  • Low profile design
    It enables flexible installation in a variety of computing systems, from small form factors to full-height systems.
Sapphire AMD FirePro W4100 - graphics card - FirePro W4100 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W4100
2 GB GDDR5
Stream Processors
512
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Single-Link): 1920 x 1200 / DVI (Dual-Link): 2560 x 1600 / DisplayPort: 4096 x 2160
Max Monitors Supported
4
Interfaces Details
4 x Mini DisplayPort , DVI - with adapter
API Supported
OpenCL 1.2, DirectX 11.1, OpenGL 4.4, DirectX 12
Package Type
Retail
3-year warranty
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W4100
Stream Processors
512
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
AMD PowerTune technology, AMD AutoDetect Technology, AMD Eyefinity Technology 2.0, Digital Multi-Point Audio (DDMA), Graphics Core Next (GCN), AMD ZeroCore Power technology, Partially Resident Textures (PRT), Video Codec Engine (VCE), D.O.P.P., HydraVision, Full 30-bit Display Pipeline, Unified Driver Architecture (UDA), Projector Overlap Support, Bezel Compensation
Size
2 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
72 GBps
Linux (64-bit), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Linux (32-bit), Windows 8.1 (32/64 bits)
Required Power Supply
500 W
Additional Requirements
DVD-ROM
50 Watt
Low-profile bracket
UL, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE
Package Type
Retail
Limited warranty - 3 years
