Mounting adapter allows a 2.5" SSD or HDD to fit into a 3.5" PC drive bay.
- Application Fits two notebook drives into PC case
- Designed for 2 x 9.5mm HDD or
- 1 x 9.5mm HDD & 1 x 12.5mm HDD on top
- Material Black SECC
- Dimensions 113(L) x 102(W) x 25(H) mm
- Akasa AK-HDA-03 - storage bay adapter
- Storage bay adapter
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 2 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- 10.2 cm x 11.3 cm x 2.5 cm
- 3.5" to 2.5"
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- 10.2 cm
- 11.3 cm
- 2.5 cm
