Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards in a single location. Includes additional USB ports and eSATA port for extra connectivity. Easy to install.
Internal USB 3.0 19 pin motherboard connector, Internal USB2.0 motherboard header & SATA connector
- Brushed aluminum fascia panel
- 6-slot card reader
- 4-port USB 2.0 HUB
- SuperSpeed USB 3.0 connection
- 2 x USB 3.0 ports, backwards compatible with USB 2.0
- eSATA port
- For 5.25" PC front bay
- Application 5.25" PC bay
- Memory Card Slot 6
- Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / 64GByte for SDXC - 32GByte for SDHC / Extreme Digital (X card, Type H, Type M) / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
- Rear connectors Internal USB 2.0 motherboard connector, 2 x USB 3.0 type A male ports, eSATA port
- Data Transfer Rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
- LED indicator Power On, Card In & Data Transfer
- USB Ports 4-port USB 2.0 HUB / 2 x USB 3.0 ports, backwards compatible with USB 2.0
- eSATA Ports 1
- Supported OS Windows 2000 / XP / VISTA / 7
- Plug & Play Supported
- Akasa InterConnect Pro - card reader - USB 2.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, CompactFlash Card, RS-MMC, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
- Host Interface
- USB 2.0
- Required Bay
- 5.25" internal
- Built-in USB hub, power indicator
- Product Type
- Host Interface
- USB 2.0
- Required Bay
- 5.25" internal
Memory Card
- Capacity
- (max)
- Additional Ports
- 1 x USB 2.0 , 2 x USB 3.0 , 3 x eSATA
- Required Ports
- 1 x 4 pin USB Type A , 2 x 9 pin USB Type A , 1 x 7 pin Serial ATA
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- Plug and Play
