Akasa 3.5" BayMaster, Multi Memory Card & 2.5" SATA HDD/SSD
Quicklinx: 7M8ZWS00 Mfr#: AK-ICR-10
BayMaster is a hard drive docking station and memory card reader in one neat device that fits into a standard 3.5" PC drive bay.
Compatible with 2.5" SATA and SSD enables you to quickly read and write data to hard drives and memory cards including SDHC, microSD, eXtreme Digital, M2, MS Pro Duo and M2 in one convenient location. The fully hot swappable function allows you to dock the drives without restarting your PC system.
Akasa BayMaster AK-ICR-10 - card reader - USB 2.0
Card reader - internal
Supported Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M
Host Interface
USB 2.0
Required Bay
3.5" internal
Host Interface
USB 2.0
Required Bay
3.5" internal
Memory Card
(max)
Additional Ports
1 x SATA-300
Microsoft Windows 2000/XP/Vista/7
Black front panel, white front panel
Plug and Play
