UV 12" cold cathode dual pack. Lights up your PC interior with bright UV light interact with UV reactive accessories to create unique visual effect. 4mm low power lights inside the clear acrylic tubes for protection. Low heat emissions and long life. Easy, tool free installation with double sided adhesive tapes.
- 2 UV cold cathode case lights
- Dual 12V inverter included
- On/off switch
- 4mm lo-power tube, only 3 watts
- Tool free installation
- Akasa AK 188-UV - system cabinet lighting (cold cathode fluorescent lamp)
- Product Type
- System cabinet lighting (cold cathode fluorescent lamp)
- Packaged Quantity
- 2 (specifications are for single item)
- Ultra violet
- Length
- 30.5 cm
- Package Type
- Retail
- Packaged Quantity
- Product Type
- Length
- 30.5 cm
- Ultra violet
- Package Type
- Retail
