The Adaptec RAID 1220SA card is a two-port, PCI Express x1 controller featuring Adaptec HostRAID - an integrated RAID technology that maximizes system performance and uptime. The Adaptec 1220SA supports up to two 3Gb/s Serial ATA drives, Native Command Queuing, and offers RAID levels 0, 1, and JBOD (individual drive). The Adaptec 48-bit logical block addressing (LBA) support enables use of disk drives exceeding 137 GB in capacity.
- Microchip Adaptec RAID 1220SA - storage controller (RAID) - SATA 3Gb/s - PCIe x1
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe x1
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive, disk array (RAID)
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD
- System Requirements
- Microsoft Windows 2000, Red Hat Linux, SuSe Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Novell NetWare 6.5
- Microsoft Certification
- Works with Windows Vista
- 8.5 cm x 6.4 cm
- 3-year warranty
- Host Bus
- PCIe x1
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Channel Qty
- 2
- 2
- RAID Level
- 2 x SATA 3Gb/s - SATA (internal)
- Compatible Slots
- 1 x PCI Express x1 - low-profile
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- RoHS
- OS Required
- Limited warranty - 3 years
- 8.5 cm
- 6.4 cm
- 0 °C
- 55 °C
