Clearer
Movies are massive at 300 inches (762 cm) and a billion colours. Action sequences are thrilling at an authentic 24p frame rate1 and with AcuMotion's blur control.1 With the superb clarity of available 1080p Full HD, you'll enjoy rich details, bright and natural colours, and exceptional contrast.
Easier
Position the picture just how you want it without moving the projector itself on models with lens shift control. Others let you choose among resolutions and aspect ratios or even among sources thanks to simultaneous connectivity. When you attach an image source, it's instantly found by Smart Detection.
More real
Movies gain depth and feeling with available 3D solutions that deliver stereoscopic visuals. Plus, those visuals are flicker free thanks to high refresh rates. Scenes and characters seem more real with keystone correction providing the perfect rectangular image. All models come with multiple connectors, including HDMI®, DVI and VGA.
More green
Enjoy your favourite movies again and again with no "burnout" thanks to Home Series projector bulbs, which in economy mode last up to 5,000 hours1 - that's more than two thousand films. Need an intermission? No eco-worries, as Acer EcoProjection technology reduces standby power consumption by up to 90%.
Clearer
Movies are massive at 300 inches (762 cm) and a billion colors. Action sequences are thrilling at an authentic 24p frame rate and with AcuMotion's blur control. With the superb clarity of available 1080p Full HD, you'll enjoy rich details, bright and natural colors, and exceptional contrast. -
Easier
Position the picture just how you want it without moving the projector itself on models with lens shift control. Others let you choose among resolutions and aspect ratios or even among sources thanks to simultaneous connectivity. When you attach an image source, it's instantly found by Smart Detection. -
More real
Movies gain depth and feeling with available 3D solutions that deliver stereoscopic visuals. Plus, those visuals are flicker free thanks to high refresh rates. Scenes and characters seem more real with keystone correction providing the perfect rectangular image. The model comes with multiple connectors, including HDMI, DVI and VGA. -
More green
Enjoy your favorite movies again and again with no "burnout" thanks to Home Series projector bulbs, which in economy mode last up to 5000 hours - that's more than two thousand films. Need an intermission? No eco-worries, as Acer EcoProjection technology reduces standby power consumption by up to 90%.
- Acer H5370BD - DLP projector - 3D - white
- DLP projector - 720p
- 3D Capable
- White
- Localisation
- United Kingdom, EMEA
- Brightness
- 2500 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- 1280 x 720
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hours - normal mode , Up to 6000 hours - economic mode
- Video Input
- (NTSC, SECAM, PAL)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 28.8 cm x 22.5 cm x 8.3 cm
- 2.4 kg
- 2-year warranty
- 3D Capable
- Enclosure Colour
- White
- Localisation
Projector
- Brightness
- 2500 lumens
- Brightness (Reduced)
- 2000 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 68.6 cm - 762 cm
- Projection Distance
- 1 m - 10.3 m
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- 1280 x 720 (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- ColorBoost II+ Technology
Lens
- Lens Aperture
- F/2.5-2.6
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Video Interfaces
- HDMI
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- AC 120/230 V
- 28.8 cm
- 22.5 cm
- 8.3 cm
- 2.4 kg
- Limited warranty - 2 years - carry-in
Acer H5370BD HD DLP Home Cinema Projector
