3M 20" Widescreen Privacy Filter
Quicklinx: 5678WS00 Mfr#: PF20.1W
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 20 3/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 17 1/8" wide x 10 11/16" high (434 mm x 272 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF20.1W - display privacy filter - 20.1" wide
Display privacy filter
Display Screen Size Compatibility
20.1" wide
20.1" wide
