ZyXEL XS1920-12 Switch 12 Ports Managed Rack-Mountable
Quicklinx: BL89WS00 Mfr#: XS1920-12-ZZ0101F
In today's rapidly changing world of cloud-based products and services, it can be difficult for large enterprises, as well as small and medium-sized businesses (SMBs) to decide how to best handle increased data and the demands of applications like VoIP, video streaming and IP surveillance. In this environment, networks need to be simultaneously faster and more reliable, as well as easy to set up and maintain. To help meet these challenges, ZyXEL has introduced the XS1920-12, a 10GbE smart switch for SMB that economically upgrades any network to high-speed 10GbE bandwidth.
  • Affordable 10GbE network connectivity for SMB
    When attempting to meet today's demand for more bandwidth, SMBs often face increased expenditures, difficult deployments and other complex issues. The XS1920-12 has been designed to overcome these challenges with ZyXEL's 10GbE smart switch technology, which features ten (10) copper 10GbE connections and two (2) 10GbE SFP+ combos for 10G fiber links, offering additional flexibility for tricky deployments. The XS1920-12's small port count design makes it the ideal choice for small businesses looking for an affordable network switch solution.
  • Upgrade the network with investment-protection
    Upgrading with the XS1920-12 is a hassle-free operation. Backward-compatibility for Gigabit network allows SMBs to leverage existing Cat5/Cat5e infrastructure. The XS1920-12 also future-proofs networks with IPv6 support and 10GbE connectivity when an SMB is ready to convert to Cat6A and above cabling. A Cat6A or above cabled network is able to use RJ45 connectors to provide higher bandwidth up to 100 m with 10GbE copper.
  • ZyXEL One Network experience
    Aiming for relieving customers from repetitive operations of deploying and managing a network, ZyXEL One Network is designed to simplify the configuration, management, and troubleshooting, allowing customers to focus on the business priorities. ZyXEL One Network presents an easy-to-use tool, ZyXEL One Network Utility (ZON Utility), to realize speed network setup. ZyXEL Smart Connect allows ZyXEL networking equipment to be aware and recognize each other and further facilitating the network maintenance via one-click remote functions such as factory reset or power cycling. ZyXEL One Network redefines the network integration across multiple networking products from switch to Wi-Fi AP and to Gateway.
  • Robust features to ensure network availability
    The XS1920-12 protects users from network disruptions caused by internal errors or outside attack and ensures uninterrupted connectivity through several key features. Loop Guard helps networks avoid service disruptions caused by switching loops, and IP Source Guard (IPSG) shields your network from MAC spoof and ARP spoof attacks. Additionally, attacks such as BPDU, ARP and IGMP can target network facilities. However, CPU protection guarantees that a network continues to operate, even while under attack. In addition, dual images and configuration support guarantee network availability and reliability. These are just some of the ways that the XS1920-12 guarantees headache-free network connectivity for SMBs.
  • Smart management and advanced functionality
    With features like L2 switching capacity, the XS1920-12 is able to function as a core switch, making it the cost-effective switching solution for SMBs. As part of the smart switch series, the XS1920-12 allows administrators to perform simplified network management via a user-friendly Web management interface.
Zyxel XS1920-12 - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
10 x 10GBase-T + 2 x combo 10 Gigabit SFP+
Performance
Switching capacity: 240 Gbps , Forwarding performance: 178.6 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, CLI
Flow control, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, SNMP trap, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), 2MB packet buffer, loop prevention, port isolation, Class of Service (CoS), tagged VLAN, IGMP proxy, ErrDisable Recovery, ZyXEL One Network (ZON), IGMP filtering, IGMP throttling, CPU protection, IP source guard, ARP inspection, policy based rate limiting
IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
44 cm x 33 cm x 4.45 cm
4.205 kg
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, system, link/activity
12 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+
Internal power supply
95.6 Watt
Rack Mounting Kit
Included
MTBF
839,624.71 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
44 cm
33 cm
4.45 cm
4.205 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
