Unlike competitors' offering of individual models for GbE copper and fiber connectivity, the leading architecture employed by XGS-4528F delivers 24 1000Base-T copper interfaces along with standard RJ-45 connectors and 24 SFP slots in a 19" 1U enclosure. This unique benefit gives network designers the highest flexibility and cost saving in terms of equipment investment, network administration and system maintenance.
With two high-performance 12G stacking ports on the back panel, over 10 units of XGS-4528F can be easily hard-stacked in a ring architecture; this feature makes XGS-4528F highly scalable and eases the network expansion and administration. Moreover, as the stacking ports come with every XGS-4528F unit, customers have no need to spend extra for stacking modules and stacking cables.
Each XGS-4528F provides 144Gbps-switching capacity for wire-speed performance delivered on all GbE copper/fiber ports within the stack, as well as stacking ports and optional 10G uplinks. In addition, advanced L3 switching, multicasting, resiliency including OSPF, DVMRP, VRRP also help delivering optimal performance to the entire network.
- Zyxel XGS-4528F - switch - 24 ports - Managed
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 24 x shared SFP
- MAC Address Table Size
- 8K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
- Flow control, Layer 3 switching, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IP address filtering, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, DHCP server
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 43.8 cm x 31 cm x 4.4 cm
- 7 kg
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8K entries
- Max Units In A Stack
- 10
- Routing Protocol
- Encryption Algorithm
- SSL, TLS
- Authentication Method
- Secure Shell (SSH), TACACS+, Secure Shell v.2 (SSH2)
- 24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x RJ-45 management , 1 x console - 9 pin D-Sub (DB-9) management , 2 x network stack device , 24 x SFP (mini-GBIC)
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply
- Voltage Required
- FCC, UL 60950-1, IEC 60950-1, EN 60950-1
- 43.8 cm
- 31 cm
- 4.4 cm
- 7 kg
- 0 °C
- 45 °C
- 10 - 90%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.19 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.62 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.24 |
