Zyxel XGS3700-24 L2/3 24 port Gigabit Switch with uplinks
THE SWITCH EXPERT
Quicklinx: 8XFYWS00 Mfr#: XGS3700-24-ZZ0101F
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
Hurry, only 3 left in stock!
£1,456.98 ex VAT
£1,748.37 inc VAT
The ZyXEL XGS3700 series are advanced Layer 2 Plus (Layer 3 Lite) Gigabit managed switches perfect for data center access, SMB core/aggregation, and mission critical PoE applications. The high redundancy hardware architecture includes dual, internal power supplies and hot-swappable fan and power modules. The PoE models also comply with the IEEE 802.3at PoE Plus standard and provide industry-leading PoE power budget of up to 1000 watts.
The ZyXEL XGS3700 series provides the flexibility to be deployed in all sorts of deployments including data center access, SMB core/aggregation, and mission critical PoE applications. The Series provides added routing flexibility with support for static routing and policy-based routing (PBR); and its full and consistent GUI, CLI and MIB ensures simplified management and consistent configurations.
  • Non-stop business continuity for mission critical applications
  • Resiliency and availability for non-stop business continuity
    The ZyXEL XGS3700 series features a no single point of failure (NSPOF) hardware and software design to provide the resiliency needed for non-stop business continuity. Its high redundancy hardware architecture includes dual, internal power supplies - which not only ensures 100% uptime in the event of a power supply failure, but also saves rack space compared to external power supplies. Additionally, both the fan module and the power supply modules are hot-swappable to enable zero downtime troubleshooting.
  • High power capacity and high availability for mission critical PoE applications
    The complete PoE portfolio provides up to 30 watts per port with IEEE 802.3at PoE Plus compliance, and is backward compatible with the IEEE 802.3af standard. This model provides an industry-leading PoE power budget of 1000 watts with dual power supply units or 460 watts with a single power supply unit. Combined with the high resiliency hardware and software features, the XGS3700 series PoE switches are ideal for mission critical IP surveillance, WLAN and high quality VoIP applications.
  • Deployment flexibility and investment protection
Zyxel XGS3700-24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: 95 Mpps
Routing table entries: 512 , Routing domains: 128
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, VRRP, static IP routing, IGMPv3, ECMP, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, ARP support, trunking, IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, RADIUS support, DHCP server, MLD snooping, bandwidth control, Equal-Cost Multipath (ECMP), LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), NTP server, IP-MAC binding, DHCP client, Management Information Base (MIB), Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), 2MB packet buffer, loop prevention, port isolation, hot swappable fan, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3aq, IEEE 802.3az
Power Redundancy
Optional
44 cm x 43.7 cm x 4 cm
7.27 kg
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
24 x 1000Base-T RJ-45 , 4 x SFP+ , 1 x console - 9 pin D-Sub (DB-9) , 1 x RJ-45 management
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
44.5 Watt
MTBF
280,000 hours
BSMI, RoHS, FCC Part 15 B Class A, LVD, EMC Class A
44 cm
43.7 cm
4 cm
7.27 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
8XFY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
8XFY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.18
8XFY C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Ports: 24
Managed: Yes
POE: No
Brand: Zyxel
Price Range Ex VAT: 1000 - 1500
