The ZyXEL XGS3600 series is Telco-class layer 2 carrier Ethernet switches ideal for Ethernet service aggregation and extension. The series is an excellent solution that provides an ideal combination of affordability with capabilities for carrier access networking.
The ZyXEL XGS3600 series L2 GbE switches offer wire-speed flow control that classifies and prioritizes the incoming packets according to the predefine QoS policies that meet requirements of service providers. In terms of classification, the Differentiated Services Code Point (DSCP) field and the 802.1p Class of Service (CoS) field is identified to assess the priority of incoming packets. Classification and reclassification can be based on criteria as specific as rules based on IP, MAC addresses, VLAN ID or TCP/ UDP port number. For bandwidth management, the XGS3600 series provides 8 priority queues per port for different types of traffics, allowing service providers to set policy-based rate limitations that take full advantage of constrained network resources and guarantee the best performance.
- Zyxel XGS3600-26F - switch - 26 ports - Managed - rack-mountable
- Switch - 26 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 20 x Gigabit SFP + 4 x combo Fast Ethernet/Gigabit SFP + 2 x 10 Gigabit SFP+
- Performance
- Switching capacity: 88 Gbps , Forwarding performance: 65.47 Mpps
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, SSH-2, CLI
- Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, IPv6 support, firmware upgradable, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, temperature sensor, Cable Diagnostics Function, bandwidth control, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), TFTP server, IP-MAC binding, SNMP trap, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy, 4MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az, ITU-T Y.1731, ITU-T G.8031, ITU-T G.8032
- Power
- AC 120/230 V / DC 48 V (50/60 Hz)
- 44.2 cm x 21.12 cm x 4.4 cm
- 3.1 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 32K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1 x MIPS: 400 MHz
- RAM
- 128 MB DDR2 SDRAM
- Flash Memory
- 32 MB
- Status Indicators
- Port status, power, system, alarm
- 24 x 10Base-T/100Base-TX/1000Base-T - SFP (mini-GBIC) , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x serial (RS-232) DB-9 , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 management , 2 x 10GBase-SR/10GBase-LR - SFP+
- Power Device
- Internal power supply
- Voltage Required
- 55 Watt
- Localisation
- United Kingdom
- 44.2 cm
- 21.12 cm
- 4.4 cm
- 3.1 kg
- 0 °C
- 65 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.07 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.44 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £40.80 |
