The XGS1910 series is ideal for securing 10/100, Gigabit and 10 GbE connectivity; it also offers IEEE 802.3az, access security, advanced prioritization, traffic-monitoring capabilities and a fanless design. Meanwhile, the series supports smooth IPv6 migration for future expansions. As a result, the XGS1910 series is suitable for fulfilling SMB network needs with cost-effective, valuable frameworks.
Smart Layer 2 features enrich access networks
The ZyXEL XGS1910 series is providing comprehensive Layer 2 switching capabilities such as Access Control List (ACL) rules, 802.1p Priority Queues per Port and 802.1AB LLDP and LLDP-MED, etc. The series delivers the essential network features for businesses with easy-to-use management at a right price. That is, the XGS1910 series is the best edge switch range for small- and medium-size businesses to build high-performance network efficiently. -
GbE bandwidth for desktops
When videos of higher resolution and data flow constantly evolve, network user demands might not be satisfied and business operations hampered by insufficient bandwidth. The ZyXEL XGS1910 series provides GbE bandwidth to desktops to ensure sufficient bandwidth for all business communications, data delivery and daily operations. Taking advantages of GbE, businesses can create premium worry-free IT environment and expand operations with desirable efficiency and productivity. -
Energy management with IEEE 802.3az
As operating overheads such as electric bills increase constantly due to the rising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) features of ZyXEL XGS1910 series can reduce energy consumption of Ethernet devices through defining low-power modes and adjusting the operating timeframe to help saving the related costs effectively.
- Zyxel XGS1910-48 - switch - 48 ports - Managed
- Switch - 48 ports - Managed - stackable
- Subtype
- Gigabit Ethernet
- Ports
- 44 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+
- Performance
- Non-blocking switching capacity: 176 Gbps , Forwarding performance: 131 Mpps
- MAC Address Table Size
- 32K entries
- Remote Management Protocol
- RMON 1, RMON 2, SNMP, RMON 3, RMON 9, HTTP
- Flow control, auto-negotiation, ARP support, trunking, VLAN support, packet filtering, store and forward, MAC address filtering, IPv6 support, IP address filtering, half duplex mode, full duplex mode, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, bandwidth control, LACP support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), IP-MAC binding, DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, loop prevention, port isolation, congestion control
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, UPnP
- Power
- AC 120/230 V (50/60 Hz)
- 43 cm x 25 cm x 4.4 cm
- 3.1 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 32K entries
- Max Units In A Stack
- 8
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+
- RAM
- 4 MB
- Status Indicators
- Power, system, alarm, link/activity
- 48 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 4 x SFP (mini-GBIC) , 1 x console DB-9 , 4 x SFP+
- Power Device
- Internal power supply
- Voltage Required
- 61 Watt
- FCC, RoHS, BSMI CNS 13438, ICES, BSMI CNS 14336, LVD
- Localisation
- United Kingdom
- 43 cm
- 25 cm
- 4.4 cm
- 3.1 kg
- 0 °C
- 50 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
