Zyxel XFP-SR 10G 300M Short Range Fibre Transceiver
Quicklinx: BW4BWS00 Mfr#: XFP-SR-ZZ0101F
The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies. Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device.
Zyxel XFP-SR - XFP transceiver module - 10 GigE
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
10 GigE
Max Transfer Distance
300 m
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
300 m
1 x Ethernet 10GBase-SR
