In the Gigabit era in Wi-Fi connectivity, upgrading to the 802.11ac standard represents the next step in wireless evolution. Many enterprises looking to break the 1-Gbps Wi-Fi speed barrier face the challenge of replacing existing 802.11n access points. While 802.11n operates on both 2.4 GHz and 5 GHz frequency band, 802.11ac predominantly uses the 5 GHz band which by its nature traditionally reduces coverage when compared to 2.4 GHz. This led to costly and time consuming efforts for installers to ensure that sufficient APs were installed to give complete coverage.
ZyXEL Smart Antenna technology is a groundbreaking feature of the WAC6500 Series of wireless APs that solves the coverage problem by adaptively adjusting antenna patterns to fit a variety of wireless environments. The Smart Antenna's industry-leading RF output power and sensitivity combine to offer greater coverage and performance over traditional networks, making ZyXEL's WAC6500 Series the ultimate one-to-one AP upgrade choice.
As well as ZyXEL Smart Antenna technology, the WAC6500 Series includes several other features including the innovative APFlexTM, tool-less mounting bracket, and many other software enhancements such as the ZyXEL One Network utilities, making the WAC6500 a complete product designed to streamline network installation and speed deployment for the best possible Wi-Fi experience.
ZyXEL Smart Antenna ZyXEL
Smart Antenna continuously applies a unique algorithm to compute the best physical-layer path for every individual client. It not only considers best signal, but also mitigates RF interference on over 700 optimized antenna patterns. The "switch-beam" technique mitigating RF interference runs at the physical layer, requiring no effort on the part of the end-user. The adaptive antenna design handles a variety of tough deployments, including high-capacity, high-performance and interference-laden environments like conference rooms, airports, classrooms and other crowded venues. -
ZyXEL APFlex ZyXEL
APFlex includes Zero-touch AP mode changing and Automatic IP configuration. The Zero-touch AP mode setting detects if there is an existing ZyXEL controller and chooses stand-alone or managed mode. The Automatic IP configuration removes manual configuration, allowing the AP to set itself to fixed or dynamic IP address automatically. With these two intelligent features, IT administrators can skip the two critical settings that were handled manually on legacy products, shifting focus to more critical configuration tasks. -
Tool-less installation WAC6500
Series features a creative mounting bracket design allowing installation of the AP in a variety of suspended ceiling tracks without the need for tools. The variable width of ceiling tracks makes the bracket universally adaptable to any building structure. Individual end-users can easily install the hardware, saving valuable time that could be better spent deploying additional APs. -
Wireless Layer-2 isolation
The Layer-2 isolation protects private networks among client users, allowing users to access their shared devices without entering the rest of a private network for enhanced security. In addition, the intra-BSS blocking prevents different Wi-Fi clients associated with the same AP from seeing each other and each others data. -
ZyXEL One Network utility
To streamline the management process, the WAC6500 Series comes with the ZyXEL One Network (ZON) utility, allowing administrators to assign IP addresses to multiple APs through just one platform. Administrators can avoid the hassle logging into each AP to change the default IP addresses before physical installation. -
ZyXEL AP Configurator
While deploying a number of APs, repetitive configuration of each unit takes time and effort. ZyXEL AP Configurator (ZAC) builds templates that allows users to copy one profile to several APs, allowing batch firmware upgrades and profile backups in three easy steps to significantly reduce configuration time and effort. -
ZyXEL Wireless Optimizer
ZyXEL Wireless Optimizer (ZWO) provides a powerful tool for centralized management covering initial planning, adjustment during deployment and after-sale maintenance of an AP network. Architects can simulate AP deployment on a map displaying the number of APs needed. During deployment, ZWO will also map actual signal coverage for architects to adjust their AP locations or configurations. After-sale, network administrators can access key performance details from ZWO, including channel in use, transmit retry rate and frame error rate, as well as the devices on the environment map. ZWO's user-friendly presentation saves time and facilitates quick response to the network problems. -
ZyMesh
Wireless Mesh is an array of access points automatically forming dynamic wireless links. Built on this foundation of mesh networking, ZyMesh is ZyXEL's proprietary protocol for creating wireless mesh links for easy configuration, optimized management and enhanced reliability.
- Zyxel WAC6553D-E - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External - outdoor
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Throughput: 900 Mbps
- Capacity
- Maximum number of configured SSIDs: 16
- Included Accessories
- PoE injector, pole mount, wall mounting kit
- Power Over Ethernet (PoE) Supported
- PoE+
- 25.5 cm x 25.6 cm x 6.2 cm
- 1.708 kg
- Ruggedized Design
- Outdoor
- 25.5 cm
- 25.6 cm
- 6.2 cm
- 1.708 kg
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- Firewall protection, VLAN support, DiffServ support, manageable, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), rogue access point detection, plenum-rated, DHCP client, Cyclic Delay Diversity (CDD), Maximum Likelihood Demodulation (MLD), security lock slot (cable lock sold separately), cyclic shift diversity (CSD), ZyXEL One Network (ZON)
- Encryption Algorithm
- TLS, PEAP, TTLS, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
- Authentication Method
- RADIUS, LDAP, Active Directory
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 6
- 1 x 1000Base-T (PoE+) - RJ-45 , 1 x console - RJ-45
- MTBF
- 562,413 hours
- EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, IP66, EN 300 328, BSMI CNS 14336-1, EN 301 489-1, EN 301 893, EN 301 489-17
- PoE+
- Power Device
- Power injector
- 25 Watt
- -40 °C
- 60 °C
- 10 - 90% (non-condensing)
