Zyxel USG110 Unified Security Gateway VPN Firewall Appliance
Quicklinx: BS97WS00 Mfr#: USG110-GB0102F
£584.19 ex VAT
£701.02 inc VAT
The ZyXEL USG Advanced Series are Next Generation Firewalls (NGFW) designed to meet the mobility, anti-malware and policy enforcement challenges in SMBs. The integrated WLAN controller offers easy WLAN scalability for the growing demand for Wi-Fi; while WAN and VPN load balancing and failover ensures nonstop business communications. ZyXEL USGs offer industry-leading anti-virus, anti-spam, content filtering and application intelligence technology for effective application optimization and comprehensive network protection.
The ZyXEL USG Advanced Series offers SMBs high network availability for always online communications. It features multi-WAN load balancing and failover, and a comprehensive mobile broadband USB modem support list for WAN backup. On top of that, the series supports IPSec load balancing and failover to provide added resiliency for the most mission-critical VPN deployments.
The ZyXEL USG Advanced Series provides extensive anti-malware protection and effective control of web applications - like Facebook, Google Apps and Netflix - with industry-leading firewall, anti-virus, anti-spam, content filtering, IDP and application intelligence. These security measures are enhanced with SSL inspection, which helps block threats that are hidden in SSL encrypted connections and facilitates deeper policy enforcement.
  • Multi-WAN and mobile broadband
    The ZyXEL USG Advanced Series provides non-stop Internet uptime with multi-WAN and mobile broadband support. Multi-WAN works with two or more Ethernet WAN connections for active-active WAN load balancing or active-passive failover. Comprehensive mobile broadband USB modems are also supported for WAN backup.
  • Robust VPN
    ZyXEL USGs support high-throughput IPSec, L2TP over IPSec and SSL VPN for a wide range of site-to-client and site-to-site VPN deployments. Reinforced with the advanced SHA-2 encryption, the ZyXEL USGs provide the most secure VPN for business communications.
  • VPN High Availability (HA)
    ZyXEL USGs feature VPN HA to satisfy the demands of the most mission-critical VPN deployments. Supporting advanced GRE over IPSec technology, users can deploy two IPSec VPN tunnels for active-active VPN load balancing or active-passive failover.
  • Integrated WLAN controller
    The integrated WLAN controller supports CAPWAP, and enables centralized authentication and access management of multiple APs in the network. The ZyXEL USG Advanced Series can manage 2 APs by default, and up to 18 APs with license upgrade.
  • Unified security policy
    Unified security policy offers object-based management and a unified configuration interface for firewall and all security-related policies. Users can easily apply all policy criteria to every UTM feature, reduce configuration time, and get more streamlined policy management.
  • Application intelligence
    ZyXEL's USG Advanced Series can identify, categorize and control over 3000 social, gaming, productivity, and other Web applications and behaviors. Users can prioritize productive applications, throttle acceptable ones, and block unproductive applications to boost productivity and prevent bandwidth abuse.
  • Anti-virus
    Powered by Kaspersky SafeStream II gateway anti-virus, ZyXEL USGs provide comprehensive and real-time protection against malware threats before they enter the network. ZyXEL USGs can identify and block over 650000 viruses right at the gate and provide high-speed scanning with stream-based virus scanning technology.
  • SSL inspection
    SSL inspection enables the ZyXEL Advanced Series to provide not only comprehensive security, but also deeper policy enforcement. It enables the USG's application intelligence, IDP, content filtering and anti-virus to inspect traffic in SSL encrypted connections and block threats that usually go unseen.
  • Anti-spam
    With a cloud-based IP reputation system, ZyXEL anti-spam can deliver accurate, zero-hour spam outbreak protection by analyzing up-to-the-minute sender reputation data from highly diverse traffic sources. It can detect spam outbreaks in the first few minutes of emergence regardless of spam language or format.
  • Content filtering
    ZyXEL content filtering helps screen access to websites that are not business related or malicious. With a massive, cloud-based database of over 140 billion URLs that are continuously analyzed and tracked, ZyXEL provides highly accurate, broad and instant protection against malicious web content.
Zyxel USG110 - UTM Bundle - security appliance - with 1 year AV+IDP, AS, CF
Security appliance
Bundled Services
Licence Qty
5 SSL VPN users
Rack-mountable
United Kingdom
Performance
Firewall throughput: 1.6 Gbps , VPN throughput: 400 Mbps , Intrusion detection and prevention throughput: 300 Mbps , Antivirus throughput: 250 Mbps , Unified Threat Management (UTM) throughput: 250 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 100 , Concurrent sessions: 60000 , Concurrent SSL VPN users: 25 , Virtual interfaces (VLANs): 16 , New sessions: 3500 , Manageable access points: 18
30 cm x 17.8 cm x 4.4 cm
2 kg
Security appliance
Bundled Services
30 cm
17.8 cm
4.4 cm
2 kg
United Kingdom
Rack-mountable
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
4 x 1000Base-T - RJ-45 (LAN / DMZ) , 2 x 1000Base-T - RJ-45 (WAN) , 2 x USB - Type A , 1 x console - DB-9 , 1 x 1000Base-T - RJ-45
MTBF
787,109.3 hours
ICSA IPSec certified, ICSA Firewall certified, ICSA Antivirus
External power adapter
37 Watt
Virus definitions update - 1 year , Intrusion definitions update - 1 year , URL Database update - 1 year , Spam filter update - 1 year
Brand: Zyxel
Price Range Ex VAT: 500 - 750
