Zyxel SFP10G-SR 10G Short Range SFP+ Transceiver
Quicklinx: 8PGHWS00 Mfr#: SFP10G-SR-ZZ0101F
Type: Modules
£145.38 ex VAT
£174.45 inc VAT
The ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barrier set by proprietary technologies.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be freely added when required, and infrastructure upgrades or transceiver repairs can be done easily by just replacing the transceiver instead of the whole device.
  • Standard-based design assures compatibility
  • Hot-swappable design facilitates network maintenance
  • Bi-directional transceivers maximizes usage of existing fiber plant
    Traditional fiber optic networking requires two strands of fiber to accomplish communications, in which one strand is reserved for sending signals, while the other is for receiving. On the other hand, bi-directional, dual-wavelength transceivers can establish communications over just one strand of fiber by using two separate optical wavelengths: one receives and the other transmits signals. Transmission capacity can be expanded immediately without additional cost laying fiber.
  • Supporting Digital Diagnostics Monitoring Interface (DDMI) SFP enhances management capability
    The enhanced digital interface enables a real time link to be established between the switch and the SFP transceiver. This enables the switch to access operating parameters within the fiber link. This includes digital features such as soft control and monitoring of SFP I/O signals.
Zyxel SFP10G-SR - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
1.48 cm x 5.65 cm x 1.185 cm
20 g
5-year warranty
Zyxel XGS1910-24, XGS1910-48
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Hot swap module replacement, Digital Diagnostics Monitoring Interface (DDMI)
1 x Ethernet 10GBase-SR - LC multi-mode x 2
Compatible Slots
1 x SFP+
TUV, Laser Class 1, FCC CFR21 Part 1040, FDA, MSA
1.48 cm
5.65 cm
1.185 cm
20 g
Limited warranty - 5 years
70 °C
Type: Modules
Brand: Zyxel
Stock Status: In stock
