Product
Zyxel SFP-100LX-20 100 Base FE Fiber Transceiver Module - 20km
Quicklinx: 8PG6WS00 Mfr#: 91-010-141001B
Type: Modules
£94.56 ex VAT
£113.47 inc VAT
ZyXEL transceiver family follows industry standards to assure compatibility with switches from other manufacturers without barriers set by proprietary technologies.
With ZyXEL's comprehensive Fast and Gigabit transceiver product range, users can just plug in the proper model to extend the physical network coverage.
Independent transceiver design provides the highest network maintenance flexibility. Transceivers can be added when required, and infrastructure upgrade or transceivers repair can be done easily by just replacing the transceiver instead of the whole device.
Zyxel SFP-100LX-20 - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
100Base-LX10
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
20 km
5.6 cm x 1.3 cm x 1.2 cm
5 years warranty
Dimension ES-2108-F
Plug-in module
Wired
Cabling Type
100Base-LX10
100Mb LAN
Data Transfer Rate
125 Mbps
Optical Wave Length
1310 nm
20 km
IEEE 802.3ah
1 x Ethernet 100Base-BX-U - LC x 2
Compatible Slots
1 x SFP (mini-GBIC)
CSA, TUV, Laser Class 1, FCC CFR21 Part 1040
5.6 cm
1.3 cm
1.2 cm
Limited warranty - 5 years
70 °C
5 - 95%
Zyxel Dimension ES-2108-F
Type: Modules
Brand: Zyxel
Price Range Ex VAT: 50 - 100
