Your basket is empty
Zyxel PLA5405-GB0201F 1200Mbps, Gigabit Ethernet Powerline KIT
Quicklinx: B8RTWS00 Mfr#: PLA5405-GB0201F
1200 Mbps Powerline Gigabit Ethernet Adapters
Expand and Enhance Your Home Network with Gigabit Powerline
The ZyXEL PLA5405 1200 Mbps Powerline Gigabit Ethernet Adapter is based on the latest HomePlug AV2 standard and features data transfer rates of up to 1200 Mbps. The Powerline adapter plugs into an existing power outlet and instantly enables high-speed network access through a home's electrical lines.
Ideal for multimedia streaming
The ZyXEL PLA5405 provides speeds of up to 1200 Mbps, accelerating network applications like HDTV, multimedia HD streaming and online gaming. Users can easily transmit multiple HD streams and even 3D movies to every room quickly and smoothly.
Perfect for streaming media and playing on-line games
ZyXEL PLA5405 - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1.2 Gbps
Network / Transport Protocol
CSMA/CA
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
TR-069
Auto-uplink (auto MDI/MDI-X), MIMO technology, Quality of Service (QoS), reset button, Type of Service (ToS)
HomePlug AV, HomePlug AV 2.0, IEEE 1901
9 cm x 6 cm x 2.7 cm
95 g
Microsoft Windows Vista / XP / 7 / 8
United Kingdom
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1.2 Gbps
Max Range Open Space
300 m
CSMA/CA
Routing Protocol
TR-069
Encryption Algorithm
128-bit AES
HomePlug AV, HomePlug AV 2.0, IEEE 1901, BSMI, EMC, FCC, LVD
Status Indicators
Power, link/activity
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
4 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
9 cm
6 cm
2.7 cm
95 g
10 - 90% (non-condensing)
