Zyxel NWD6605-EU0101F AC900 Dual-Band Wireless-AC USB Adapter
Quicklinx: 99J0WS00 Mfr#: NWD6605-EU0101F
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • IEEE 802.11n
12 in stock
£28.73 ex VAT
£34.47 inc VAT
Superior Wireless Connection for HD streaming
The ZyXEL NWD6605 Dual-Band Wireless AC1200 USB Adapter delivers data at up to 300 Mbps* for 2.4 GHz or 867 Mbps* for 5 GHz. It comes with two antennas that enable it to deliver a wider coverage and provide better wireless performance. It's ideal for HD video streaming, online gaming, and multi-thread downloading and sharing multiple large files simultaneously.
Dual-band avoids network clutter and optimizes HD media experience
The ZyXEL NWD6605 provides users the ultimate visual experience over the dual-band network and takes advantage of the common 2.4 GHz band for Web browsing with faster speeds or the interference-free 5 GHz band for smooth HD video playback and online gaming. Dual internal and external antennas reach a wider coverage for good network connection quality even you are a distance away from the wireless router or access point.
USB 3.0 interface for high-speed network experience
With transfer data rates of up to 5 Gigabit per second, the USB 3.0 interface is 10 times faster than USB 2.0. The NWD6605 adopts USB 3.0 interface to realize the true high-speed network experience.
Easy setup with Wi-Fi Protected Setup (WPS)
The friendly one-touch button design provides an easy, intuitive way to setup a secure wireless network. Just press the WPS button to enjoy the protected network in seconds.
  • 802.11ac for data transfer rates of up to 867 Mbps
    With the 802.11ac wireless standard, ZyXEL's NWD6605 provides high wireless throughputs of up to 300 Mbps at 2.4 GHz or 867 Mbps at 5 GHz. The NWD6605 is backward compatible with all your current wireless routers or access points and offers better wireless performance for video streaming and online gaming.
  • Dual-band avoids network clutter and optimizes HD media experience
    The ZyXEL NWD6605 provides users the ultimate visual experience over the dual-band network and takes advantage of the common 2.4 GHz band for web browsing with faster speeds or the interference free 5 GHz band for smooth HD video playback and online gaming. Dual internal and external antennas reach a wider coverage for good network connection quality even you are a distance away from the wireless router or access point.
  • USB 3.0 interface for high-speed network experience
  • Easy setup with Wi-Fi Protected Setup (WPS)
Zyxel NWD6605 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
9.5 cm x 2.9 cm x 1.3 cm
20 g
Europe
802.11ac
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Apple MacOS X 10.6, Apple MacOS X Lion 10.7, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions), Apple MacOS X 10.8
Network adapter
External
USB 2.0
Europe
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External integrated and internal
Antenna Qty
2
1 x USB extension cable (external)
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
LVD
1.6 Watt
9.5 cm
2.9 cm
1.3 cm
20 g
10 - 90% (non-condensing)
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: Zyxel
Price Range Ex VAT: 0 - 50
