The ZyXEL NWA5123-NI 802.11 a/b/g/n Dual-radio Uniied AP consists of 2.4 GHz and 5 GHz dual-band radio to match the concurrent Wi-Fi services with either frequency. The higher frequency of the 5 GHz band provides a shorter signal range compared to the 2.4 GHz band with the same transmit output power. The NWA5123-NI consist of high 5 GHz transmit output power can boost the 5 GHz signal range, providing signal coverage equal to the 2.4 GHz wireless network. Therefore, the complexity of deployment can be considerably reduced.
- Zyxel NWA5123-NI - radio access point
- Radio access point
- Packaged Quantity
- 8 (specifications are for single item)
- Form Factor
- In-ceiling
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 8
- Power Over Ethernet (PoE) Supported
- PoE
- 13 cm x 13 cm x 5.45 cm
- 250 g
- Packaged Quantity
- 13 cm
- 13 cm
- 5.45 cm
- 250 g
- Form Factor
- In-ceiling
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- 64 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- Remote Management Protocol
- CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, plenum-rated, DHCP client, ceiling mountable, Maximum Likelihood Demodulation (MLD)
- Encryption Algorithm
- TLS, PEAP, TTLS, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Gain Level
- 5 dBi
- 1 x 1000Base-T (PoE) - RJ-45
- MTBF
- 781,396 hour(s)
- ETSI, BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15 E, BSMI CNS 13438, EN 301.893, EN 60601-1-2, BSMI CNS 14336
- PoE
- Power Device
- External power adapter
- Installed Qty
- 0
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
