Superior Coverage from Multifunction Ceiling Mount Access Point
The ZyXEL NWA1120 Series is a standard-based, SNMP-managed PoE Access Point (AP) that includes two 802.11n models: the 2.4 GHz NWA1121-NI and concurrent 2.4/5 GHz NWA1123- NI as well as the newly introduced NWA1123-AC featuring the advanced 802.11ac technology. The smoke detector look exterior makes the NWA1120 Series perfect for indoor ceiling-mount installation; with the optimized antennas built-in, its design solves the common interference issue in ceiling-mount deployments. The NWA1120 Series supports multiple operating modes, such as wireless client and repeater, which make it an ideal, flexible solution for small business, hotels and school nvironments.
Ceiling-mount design with best interior wireless performance
Different from traditional business wireless APs struggling between performance and environment cohesion, the ZyXEL NWA1120 Series of PoE AP features embedded antennas and ceiling-mount capability without sacrificing wireless performance. In typical ceiling-mount installations, the access points with external antennas are mostly hidden in the plenum area; to prevent performance degradation, the antennas usually stick out of the ceiling—messy for indoor deployments. The smoke detector-style exterior of ZyXEL NWA1120 Series is suitable for ceiling installation that prevents equipment theft. Although the NWA1120 Series uses built-in antennas, it outperforms APs with internal antennas and blends into the interior better as well.
In addition, the ZyXEL NWA1120 Series adopts non-toxic casing material, since it’s usually placed in plenum areas, to prevent hazardous vapor emission in case of fire; this is especially important to public venues such as offices, hotels and schools.
ZyXEL ONE Network experience
Aiming for relieving our customers from repetitive operations of deploying and managing a network, ZyXEL ONE Network is designed to simplify the configuration, management, and troubleshooting, allowing our customers to focus on the business priorities. ZyXEL ONE Network presents an easy-to-use tool, ZyXEL ONE Network Utility (ZON Utility), to realize speed network setup. ZyXEL Smart Connect allows ZyXEL networking equipment to be aware and recognize each other and further facilitating the network maintenance via one-click remote functions such as factory reset or power cycling. ZyXEL ONE Network redefines the network integration across multiple networking products from switch to Wi-Fi AP and to Gateway.
High-density with high-quality user experience
It’s now common for a user to carry two or more devices that use different Wi-Fi bands; this challenges many places that still use legacy Wi-Fi AP with insufficient capability to serve the high-bandwidth devices. Both NWA1123-NI and NWA1123-AC are compatible with concurrent 2.4 GHz and 5 GHz Wi-Fi bands to support more users at the same time. Featuring the latest IEEE 802.11ac technology, including the expanded channel binding of 80 MHz and the highest 256 QAM (Quadrature Amplitude Modulation), the new NWA1123-AC delivers data speeds of up to 3 times faster. This brings the best user experience through higher number of parallel video data streams for minimized latency on the network.
Easy RF planning with same 2.4 GHz and 5 GHz signal coverage (NWA1123-NI, NWA1123-AC)
Most Wi-Fi devices around us operate in the crowded 2.4 GHz band where only three non-overlapping channels can be used for deployments, and complaints for the unsatisfactory network performance are not uncommon. As many recent mobile or laptop devices support both 2.4 GHz and 5 GHz bands, users tend to choose the 5 GHz band as their first priority; as a result, serving the 5 GHz devices becomes more important than before. However, the coverage of the higher-frequency 5 GHz band is inherently smaller comparing to the 2.4 GHz band, given the same output power. With a fine-tuned 5 GHz radio mechanism that boosts performance at the frequency, the coverage of NWA1123-NI and NWA1123-AC becomes comparable to which at the 2.4 GHz band to reduce the complexity of deployments considerably.
Multi-operation flexibility and practical business features
The NWA1120 Series of PoE Access Points supports multiple operating modes including stand-alone access point, wireless client and repeater/root-AP mode. The wireless client mode enables office peripherals like printers or fax machines to connect to the network in case they are located in places difficult for cabling. The NWA1120 Series also extends Wi-Fi services utilizing the repeater or root-AP mode to prevent excessive cable constructions. The NWA1120 Series is the best choice for small businesses for its practical features designed for business deployments: multiple SSID, solid Wi-Fi security of WPA2 Enterprise, Layer-2 isolation and 802.1 x radius authentication. All these practical features along with the high-performance RF design make the ZyXEL NWA1120 Series the best solution for building flexible Wi-Fi networks in small businesses.
Multifunction ceiling-mount design benefits large interior wireless deployments
Different from traditional business wireless APs struggling to provide better coverage or performance, the ZyXEL NWA1121-NI 802.11 b/g/n PoE AP has a "multifunction" design that solves all problems. It embeds antennas without sacrificing wireless performance, while the ceiling-mount design fulfills non-invasive deployment needs with factory-optimized coverage, especially for hospitality and education areas. -
8 SSIDs for comprehensive user management
In different public environments, the administrators may use VLAN switches to separate the traffics from different type of users; as such different group of users may need independent Wi-Fi security settings too. The ZyXEL NWA1121-NI provides up to 8 SSIDs to map the VLAN security level settings to classify users for different application services, such as public Internet access or restricted web contents. This function allows businesses to make consistent user management in wireless edge. -
IPv6/IPv4 compatibility for future-proof expansions
Designed to solve the IPv4 exhaustion problems, the IPv6 architecture is being widely adopted in worldwide deployments. With IPv6 features enabled, the ZyXEL NWA1121-NI ensures businesses with a smooth migration path from the IPv4-based networks to the full IPv6 infrastructure. The NWA1121-NI supports dual-stack that allows coexistence of both IPv4 and IPv6. With IPv6, the NWA1121-NI can meet the networking trend and make all investments future-proof. -
11n wireless technologies enhance coverage for up to 50%
Although 11n is the mainstay wireless standard, it still has a few unsolved problems such as dead spots and inefficient coverage due to the output power limited by regulations. The ZyXEL NWA1121-NI features coverage-enhancing 11n technologies such as TX Beamforming, LDPC and MLD to solve these issues. With MLD, the NWA1121-NI improves Signal-to-Noise Ratio (SNR) for about 3 dB that make wireless services even more stable and better to satisfy more mobile users.
- Zyxel NWA1121-NI - radio access point - Wi-Fi
- Radio access point
- Form Factor
- In-ceiling
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 100/230 V (50/60 Hz)
- 13 cm x 13 cm x 5.45 cm
- 230 g
- 13 cm
- 13 cm
- 5.45 cm
- 230 g
- Form Factor
- In-ceiling
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Remote Management Protocol
- SNMP, SNMP 3, HTTP, CLI
- Frequency Band
- 2.4 GHz
- VLAN support, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, RADIUS support, Auto Traffic Classifier (ATC), Multiple SSID support, 2T2R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, DHCP client, Cyclic Delay Diversity (CDD), Maximum Likelihood Demodulation (MLD)
- Encryption Algorithm
- TLS, PEAP, TTLS, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az
Aerial
- Antenna
- Internal
- Gain Level
- 7 dBi
- 1 x 1000Base-T (PoE) - RJ-45
- MTBF
- 627,152 hours
- FCC Part 15.247, RoHS, IEC 60950-1, EN 60950-1, FCC Part 15.107, DGT, EN 300 328, EN 301 489-1, EN 301 489-17
- PoE
- Power Device
- External power adapter
- Voltage Required
- 4 Watt
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
