Cloud Media Stream, Cloud HD Boost
The ZyXEL NBG6716 Simultaneous Dual-Band Wireless AC1750 HD Media Router is designed for enabling smoother multimedia streaming through the latest AC technology. With StreamBoostâ„¢ support, the Smart QoS intelligently identifies, classifies and manages all the traffics on your home network to dynamically give each application the bandwidth and speed it requires for the best online experience.
Latest 802.11ac wireless technology 3 times faster than 802.11n
The ZyXEL NBG6716 provides high-throughput of up to 1300 Mbps*, 3 times the speed of 802.11n technology at the 5 GHz band. The NBG6716 can deliver high-quality full-HD video to multiple users throughout the house.
True dual-band radio optimized for High-quality HD media, gaming and Web browsing
The ZyXEL NBG6716 enables you to enjoy HD video streaming. Users can browse the Web on the 2.4 GHz band while watching HD video or play online games over the less-crowded 5 GHz band with smooth playback and low latency.
Specialized Smart QoS for the best movie, video and gaming experience
The ZyXEL NBG6716 adopts Smart QoS that takes advantage of the intelligent StreamBoostâ„¢ adaptive routing technology to bring unprecedented performance to home networks. It prioritizes bandwidth usages for optimized multi-stream HD video, gaming, IP voice services and Web browsing through assigning appropriate bandwidths to each application automatically. Smart QoS features an intelligent patent-pending algorithm that handles streams automatically to manage Internet traffic flows without user configuration; and it also minimizes the impact from large packets and lower-priority traffics on latency-sensitive tasks to effectively eliminate interruption to online games and video steaming applications.
- The maximum wireless data transfer rates of up to 450 Mbps at 2.4 GHz and 1300 Mbps at 5 GHz in simultaneous transmission are derived from the IEEE Standard 802.11 specifications. Actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
802.11 a/c wireless technology 3 times faster than 802.11n
The ZyXEL NBG6716 provides high-throughput of up to 1300 Mbps, 3 times the speed of 802.11n technology at the 5 GHz band. The NBG6716 can deliver high-quality Full-HD video to multiple users throughout the house. -
True dual-band radio optimized for high-quality HD media, gaming and web browsing
The ZyXEL NBG6716 enables you to enjoy HD video streaming. Users can browse the web on the 2.4 GHz band while watching HD video or play online games over the less-crowded 5 GHz band with smooth playback and low latency. -
The ZyXEL NBG6716 adopts Smart QoS that takes advantage of the intelligent StreamBoost adaptive routing technology to bring unprecedented performance to home networks. It prioritizes bandwidth usages for optimized multi-stream HD video, gaming, IP voice services and web browsing through assigning appropriate bandwidths to each application automatically. Smart QoS features an intelligent patent-pending algorithm that handles streams automatically to manage Internet traffic flows without user configuration; and it also minimizes the impact from large packets and lower-priority traffics on latency-sensitive tasks to effectively eliminate interruption to online games and video steaming applications.
- Zyxel NBG6716 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1300 Mbps
- PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
- Routing Protocol
- IGMPv2, IGMP
- Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, MAC address filtering, VPN passthrough, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, bandwidth control, NetUSB support, StreamBoost
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, UPnP, IEEE 802.11ac
- 21.4 cm x 7.4 cm x 16.5 cm
- 460 g
- Localisation
- Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1300 Mbps
- Routing Protocol
- IGMPv2, IGMP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, UPnP, IEEE 802.11ac, EMC, FCC, LVD
- Status Indicators
- Power, WAN, LAN, wireless, USB, WPS
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- 20.5 Watt
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 21.4 cm
- 7.4 cm
- 16.5 cm
- 460 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
